Jet chip!
Old Mar 22, 2006 | 10:27 PM
  #21
DakotaStone's Avatar
DakotaStone
Default RE: Jet chip!
ORIGINAL: white26golf
I have the Jet stage I. This module does work with the 05+ 3.7 and 4.7 models because they are detuned from the factory unlike previous models. I have noticed gains with it on and a decrease with it off. You should only go to a stage II if you can lower your operating temps. I.E. thermostat or electric fan.
I got my chip last night. Which module did you put it on? The pic is a little unclear. I figured it to be the second from the top after orientating the pic #2 with the ECU. Also, how the hell do you get the connector off of the ECU? I slipped the red clip, but it won't come off.
Todd
Old Mar 22, 2006 | 10:48 PM
  #22
white26golf's Avatar
white26golf
It is the second plug from the top. Once you pop the clip off, you kind off just have to wiggle and pull until it coms off. I pulled off the top plug too to get to the second one. It might be a tight fit to put the chip and the plug back on, so you might have to take off the air box as well.
Old Mar 22, 2006 | 11:02 PM
  #23
DakotaStone
Thanks. It's a bitch to get off. I'll try again.
Old Mar 22, 2006 | 11:28 PM
  #24
DakotaStone
Got it. The only thing that makes me nervouse is that the connectors are a lot easier to take off now. I pushed them on as far as they'll go.
Ok... I've added a new CAI (9 hp/10lbs), new exhaust (15hp?/20lbs?), and a new chip which how much power?
Old Mar 22, 2006 | 11:45 PM
  #25
DakotaStone
Never mind. Here's a link to a company that already dynoed the 3.7 and 4.7 engines. http://www.rpmoutlet.com/dodged.htm
They rate it at 15hp/19lbs for the 4.7 and the 3.7 is 8hp/13lbs. Not bad. So I guess I've put in about 40hp and 50lbs of torque. Too bad I'm going to have to go out and find someone in the Portland area that does a dyno for AWD.
Old Mar 23, 2006 | 11:21 AM
  #26
luvmydak's Avatar
luvmydak
It was tough pulling out the stock connectors, just had to be careful not to wiggle too much to avoid damaging the pins. Did you make sure you got a click when you pushed the Jet chip into the ECU? You probably noticed there is a clip on the chip that must snap over a little tab on the ECU. It took some effort but I got it.
Old Mar 23, 2006 | 12:40 PM
  #27
ssenay's Avatar
ssenay
As far as a thermostat goes, you can probably take a 195 and drill a 3/16 hole in it like stewart does on their custom thermostats.
Old Mar 23, 2006 | 01:20 PM
  #28
DakotaStone
I felt the click between the two modules when I popped it back on, but I can still take it off with a lot less effort than when I first took it off.
I drove it last night and I can fell a difference. The throttle responds a lot quicker, and I have to watch how fast I'm going. I don't have to push down as hard to get to 25mph. I caught myself a couple times last night.
Old Mar 23, 2006 | 09:50 PM
  #29
ssenay's Avatar
ssenay
Well i got my airraid and the JET Stage 2 in today, i didnt notice any temperature difference at all. Running the same as it always did temperature wise. It moves much better now
Old Mar 23, 2006 | 10:00 PM
  #30
fourdaywillie's Avatar
fourdaywillie
What did you put the chip in? And does it make that much of a difference? $? And finally does it afect gpm?
