Dual Exhausts
Old Dec 3, 2011 | 07:09 AM
Alfons's Avatar
Alfons
Originally Posted by damyankee84
You need some kind of connection between the 2 pipes, wether is an X pipe, H pipe or a dual in/dual out muffler that has an X built into it. The reason for this is to equalize the pressure between the left and right sides of the engine. If you dont do this then you actually will loose power.
You're right, and after a bit of research (which I should have done before saying it wasn't necessary), it's obvious. Here's a link to a good explanation on the subject.
Old Dec 3, 2011 | 08:43 AM
Ok then we do need a crossover.
Old Dec 3, 2011 | 09:17 AM
Alfons's Avatar
Alfons
I guess it's that or really large diameter exhaust pipes
I'm going to give this some more thought to see what type of exhaust coupling I want to put into this system. I'm currently thinking that I might want to fabricate the traditional H as well as an X and to try each with straight pipes before I make up my mind, but to do that, I'll have to wait for warmer weather.
Old Dec 3, 2011 | 12:45 PM
FrenicX's Avatar
FrenicX
Dual in/out borlas! they sound soooo nice.
Old Dec 3, 2011 | 03:28 PM
damyankee84's Avatar
damyankee84
I would like to know which gives the best performance, either the H or X pipe. You might not think it makes a difference but it does. Some engines perform better with one and not the other.
Old Dec 3, 2011 | 04:32 PM
JimBio's Avatar
JimBio
X pipe better top end power
H pipe better low end torque
Either way you need one, without them it sounds really annoying like a farm truck with glasspacks. Pap Pap Pap Pap
I had an X pipe on my dual system, it's a sound you can not re-create with a single exhaust, really nice.
Old Dec 3, 2011 | 07:57 PM
So, can you get a dual in dual out muffler with the crossover built in or does it have to be closer to the engine?
Old Dec 3, 2011 | 08:25 PM
damyankee84
Yes you can get a muffler with a dual in dual out with built in X from gibson. http://www.gibsonexhaust.com/cftmufflers.html Now as far as how close it needs to be to the engine I have no idea.
Old Dec 3, 2011 | 08:44 PM
Alfons's Avatar
Alfons
Here's an article with a lot of information to digest.
Old Dec 12, 2011 | 07:16 AM
Blown287's Avatar
Blown287
Here you go.
http://www.youtube.com/watch?v=eTmNzBD7u2I
