Best performance for 1,600
I was told by hemifever that SCT cannot do a tune on a 4.7 with the 6speed getrage thus leaving superchips.
What is the scoop with the injectors? without forced induction how is there any gain? also wont you run rich without a tune (remember no SCT for manual)....
I would do gears... get the expensive stuff out of the way.
Tuners and fans and stuff are cheap. A set of 4.10s will wake that manual trans right up. 1600 seems to be the going rate for a front and rear set, installed. (although, I bet you could pull it off at your shop. and have money to spare.)
Was that a high output 4.7 or a regular 4.7. I seem to recall the 4.7 made 220 at the crank. Did you have 4wd or 2wd?
As soon as I get the 68.5 tb I'll be dynoing mine. A 2005 club cab 4x4 HO with limited slip and AWD. What was considered stock? Wish I had found a dyno before I started the mods.
I don't know why but my truck runs fine with the injectors. Goes through a little more gas but runs a little better too
