tire size question!!
Old 12-06-2011, 01:53 AM
06whitedak's Avatar
06whitedak
06whitedak is offline
Default tire size question!!
i know there are a million threads bout tire sizes. but i was offered a deal on a set of tires that is just to good to pass up!! but i just want to make sure they will fit. my stock size is 265/65r17 and the tires are 255/75r17. now from what i understand if im doing the math right they will be almost the same height just a little bit wider correct? please correct me if im wrong. thank you
Old 12-06-2011, 01:58 AM
FrenicX's Avatar
FrenicX
FrenicX is offline
265/65/17 = 30.6x10.4/17
255/75/17 = 32.1x10/17
Might rub.
Old 12-06-2011, 02:01 AM
06whitedak's Avatar
06whitedak
Might rub.
so they are narrower and not wider and 1.5" taller
Old 12-06-2011, 02:02 AM
marcsnyder05's Avatar
marcsnyder05
marcsnyder05 is offline
the 255/75/17 are 32.05" tall where are the stock size is 30.56" tall. I'm pretty sure you'll need a leveling kit or body lift to make them fit. Here is a good website for tire sizes
http://www.1010tires.com/TireSizeCalculator.asp
Old 12-06-2011, 02:13 AM
FrenicX's Avatar
FrenicX
FrenicX is offline
Thats just a straight up calculation, the width of the tire is probably exactly the same.
06whitedak's Avatar
06whitedak
thats an awesome website. thanks for sharing it. looks like 255/70/17 would be the better one to go with. oh well!!
Old 12-06-2011, 02:19 AM
FrenicX's Avatar
FrenicX
FrenicX is offline
That is a great one, it tells you your speedometer difference too. Here's the one I've been using, it tells the width too.
http://www.redrock4x4.com/tireconver...Name=Calculate
Old 12-06-2011, 08:39 AM
dakotaff's Avatar
dakotaff
dakotaff is offline
My opinion is that I'd go with the 265/65/17 over the 255/70/17. The wider tire looks better on a truck, even if it's just a small amount wider.
But if you're getting a great deal on the 255/70's, it would probably be worth it. You may have to trim with that size though, it should only be a small amount though.
Unless you're leveled, then you'd be good to go.
Old 12-07-2011, 12:06 AM
cheeseburger's Avatar
cheeseburger
cheeseburger is offline
they will rub DEFINITELY!!! you will need a body lift or a leveling kit or both. and you will still have to cut a pound of plastic out of your truck
Old 12-07-2011, 12:35 AM
Dakkkota's Avatar
Dakkkota
Dakkkota is offline
with the sig picture you have...you should take a look at a bodylift/leveling kit combo and use 33''
Quick Reply: tire size question!!
