shift kit vs programmer
Old Dec 11, 2011 | 08:46 PM
thunder98110's Avatar
thunder98110
i did an ho swap about 6months ago. i had ho cams in my standard motor and they rocked. the full HO motor is better than just standard 4.7 and HO cams. the heads and crank is where the major differences are in the motors. if you have the $$$$$ and want to boost your truck swap a HO motor. if you want some nice power just do ho cams.
Old Dec 11, 2011 | 08:47 PM
cruzer23's Avatar
cruzer23
Torque: 329 ft-lbs. @ 3600 rpm
Horsepower: 302 hp @ 4600 rpm
2008+ 4.7L
but would it work with out computer and trans?
can get one local junk yard $2000
Old Dec 11, 2011 | 08:57 PM
thunder98110
thoes numbers are at the crank. and the 08+ are DBW
Old Dec 11, 2011 | 11:11 PM
FrenicX's Avatar
FrenicX
Originally Posted by jkeaton
I'm pretty sure the hipotek is worth better than 1 hp. I think the difference between a 68.5mm and a 70mm bore is 1hp, but going from 65 to 68.5 is , I thought, 10-15 hp??
my mistake :P I must have understood an earlier thread wrong. I will definitly be getting one after feb. then
still much better than my 230 crank 175 rwhp though. What's DBW?
Old Dec 11, 2011 | 11:26 PM
thunder98110
Drive by wire.
Old Dec 11, 2011 | 11:42 PM
Dakkkota's Avatar
Dakkkota
dont forget the sonnax... and e-fan and true dual exhaust
Old Dec 12, 2011 | 08:06 AM
cruzer23's Avatar
cruzer23
what do i need from sonnax?
Old Dec 12, 2011 | 10:44 AM
Dakkkota's Avatar
Dakkkota
line booster...so the oil pressure in the tranny is higher...its a 39$ easy 5 min mod.
Old Dec 12, 2011 | 11:56 AM
KS Cowboy's Avatar
KS Cowboy
Originally Posted by cruzer23
i would hope the throttle body is worth more than 1hp otherwise not worth the $$
any opinions on doing the HO swap? or how hard?
IF I were to do a swap, Id probably get an Hemi instead of the 4.7, cause a 4.7 HO would cost probably be as much (possibly more than) as an hemi, but Hemi's are a little bit more avaliable, and there would be more aftermarket stuff for them. Just a thought.
Old Dec 12, 2011 | 11:59 AM
Dakkkota's Avatar
Dakkkota
and charlies pan offer a swap pan now
