got my doner radio
Old Dec 28, 2011 | 04:08 PM
reagor's Avatar
reagor
Default got my doner radio
so i posted before about adding rca outputs to a res radio (internal amp no uconnect)
i got a donor radio and have begun preliminary research
i noticed the 10 pin uconnect plug is in the radio even though it doesnt have the call button
this connector has audio outputs (are they always enabled, and are they amped?)
the chips on the board have some sort of glue on them to obscure the labels
there is a 12 conductor ribbon cable connecting the cd drive to the main board
there is a TDA7563AH amp chip http://html.alldatasheet.com/html-pd...TDA7563AH.html
the pins i am going to use are 14-16, pin 14 being the signal ground
these are the inputs for the ampchip for the rear channels
they are the 3 middle pins on the chip
i have to wait to go further as i dont have the my soldering station or rca connectors here
i plan to drill a hole in the unused grey part of the connector for the rca outputs
edit:
does anyone know if the factory radio needs the can bus to turn on ? or can i just give it 12volts
also pinouts can be found here http://www.nitroforumz.com/showthread.php?t=390
Old Dec 30, 2011 | 05:59 PM
reagor's Avatar
reagor
Well I hooked up the doner radio today and the dak doesn't like it, starts flashing lights at me and wont stay running
My guess is the radio has the old vin stored/ ecm has orig radio serial programmed
Is there a way to tell the truck to use the new radio without a dealer trip?
Old Dec 30, 2011 | 06:03 PM
i dont have a clue...lol...what kind of "donor" radio are you trying to use?
Old Dec 30, 2011 | 06:05 PM
reagor's Avatar
reagor
A factory res radio from ebay, same model I have currently
Old Dec 30, 2011 | 06:07 PM
well, i swapped mine and did not have any problems with it. have you already started wiring changes or other modifications?
Old Jan 2, 2012 | 12:19 AM
reagor's Avatar
reagor
well i bit the bullet and took my factory radio apart and added the rca wires to it
hooked it all up and viola it works
only downside is a get a lil pop when i turn the car on, guess ill have to live with it
i put a old 8" kicker cvr in a truck box with a 150x2 kicker amp
the box is behind the driver side rear seat and the amp is under the seat, with the speaker there the seat no longer lifts up
Old Jan 2, 2012 | 01:36 AM
FrenicX's Avatar
FrenicX
then turn it up louder
nice job too, I might try something like that when I get a factory aux input radio.
Old Jan 2, 2012 | 01:41 AM
reagor's Avatar
reagor
I got a res without uconnect already modded i paid 30 you can have it for the same. It has the aux port
Old Jan 25, 2025 | 05:23 PM
ikel's Avatar
ikel
Default Did you get to know the voltage for this radio?
I would really like to know please
Old Jan 25, 2025 | 07:14 PM
13 year old thread. Don't expect an answer.
Start your own thread, tell us what you are driving, what you are attempting to do, and what all you have done in that direction. Help us help you.
