if the springs are anything like that picture, they really can't fit. we have a spring that starts narrow and goes wide. a straight wide spring will have nowhere to sit in our strut.
i thought the same thing!
so i called and talked to someone and the guy said that once you choose the diameter youu want and then when you choose the weight amount you want thats wen they make the first coil the size youll need it to be
I have an 06 Quad Cab with v8 and 4x4. 75K miles. 'Not satisfied with the ride... It will bottom out on a slow speed-bump, and "chatter" crossing a RR at 55. Also get that slow bounce going through a dip. Help! Tell me what I need. Thanks, mackle
Sounds like you need some new struts and/or shocks. (Rancho or Monroe, not OEM replacements) That should stop the bottoming out and bouncing down the road.
As far as any chatter, you might have to check the front end parts, our trucks are famous for the weak front end.
