sonnax installation
Old Feb 2, 2012 | 08:42 PM
Designer's Avatar
Designer
Default sonnax installation
Anyone got any help to where this thing goes. I've looked through the threads and the service manual. Someone point me in the right direction.
Old Feb 2, 2012 | 08:55 PM
FrenicX's Avatar
FrenicX
Its under some of the heat shield, insulation stuff. You'll have to pull it back to get to the connector. That's just what I got from the fluid pressure DIY in the ram forums. I'd link it if I wasn't on my phone.
Old Feb 2, 2012 | 09:01 PM
Designer's Avatar
Designer
Yes, found it and done. Do I need to disconnect the battery?
Old Feb 2, 2012 | 09:16 PM
FrenicX's Avatar
FrenicX
Its a good idea, I'll probably forget when I do mine.. I don't think it will harm anything since its just an ultra low voltage pressure sensor.
Old Feb 2, 2012 | 10:00 PM
thunder98110's Avatar
thunder98110
it helps the computer learn the new shift pressure. you should do it.
Old Feb 2, 2012 | 10:10 PM
zcg4755's Avatar
zcg4755
How much did that Sonnax cost you?
Old Feb 2, 2012 | 10:24 PM
thunder98110
50 bucks
Old Feb 2, 2012 | 10:25 PM
MoparMan1991's Avatar
MoparMan1991
They usually sell for about $40-$50 USD.
http://lmgtfy.com/?q=sonnax+545rfe+pressure+booster
Old Feb 3, 2012 | 12:25 PM
varnerhba's Avatar
varnerhba
will a sct tuner do the same thing as the sonnax line pressure booster?
Old Feb 3, 2012 | 12:29 PM
The sonnax only comes to play under WOT. I notice a real diference between it by itself and it with the tuner.
