Trailer light wire questions...
Old 02-23-2012 | 10:26 AM
thecause17's Avatar
thecause17
Give me all the color codes for your wires and I will match them up to mine and give you the layout.
Old 02-23-2012 | 10:45 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
The layout is the same as this.
What colors Dodge uses for each position is what he needs.
The 4-Pin will be the same wires minus the Battery Wire, Reverse Light Wire, and the Brake Controller Wire.
Old 02-23-2012 | 10:50 AM
only here can we tell another guy he has a nice ***....his trucks, that is.
Old 02-23-2012 | 10:54 AM
FrenicX's Avatar
FrenicX
I love my dak. but it's certainly the type of body that I'd rather walk behind than look straight in the face. or even 3/4 angle. the "paper bag over the head" thing comes to mind.
Old 02-23-2012 | 10:55 AM
lghtngblt02
I totally missed that innuendo...
Old 02-23-2012 | 11:14 AM
you must be getting old....
Old 02-23-2012 | 11:27 AM
lghtngblt02
I think you guys are rubbing off on me, errr I mean influencing me... I give up!
Old 02-23-2012 | 11:38 AM
reagor's Avatar
reagor
did your dak happen to be in an accident before you bought it ...maybe a bodyshop cut and sealed the connectors after a rebuild?
list the wires colors in both sides of the y
do any match from side A to side B
4 pin = left turn, right turn, park, ground
7 pin = left turn, right turn, park, ground, reverse, break signal, and 12v+ iirc
get a test light and turn your headlights and hazards on start probing your wires
shouldnt be that hard to figure out
Old 02-23-2012 | 02:15 PM
Bajabob's Avatar
Bajabob
Like Reagor said. Use a static test light and have someone hit the brakes, turn signals and lights one at a time and you will have your wiring coded then when you buy the plug it will have the pin orientation in the instructions.
Old 02-23-2012 | 07:32 PM
suckerpunch's Avatar
suckerpunch
Quick Reply: Trailer light wire questions...
