Seat cushion cover
Old Mar 26, 2012 | 02:13 PM
sdsdsd's Avatar
sdsdsd
Default Seat cushion cover
Has anyone changed their front seat cushion cover with a new factory cover yet?
2005 Quad cab
Old Mar 27, 2012 | 10:56 AM
Robk1971's Avatar
Robk1971
I haven't changed mine but want to because one is cut (was like that when I bought the truck used). Not sure what you need to know, but I have had all my seats apart down to the frames to clean the covers and I can say they are the easiest seats I've ever taken apart. The days of the hog rings are long gone! After doing it once, I could pull a seat and take it apart in much less than an hour. Taking the cover of the headrest was a bit of a witch because of the tight fit, but still not bad.
I got a quote from the dealer once for both covers (backrest and seat cover), and if I remember right it would cost around $600.00 to recover each seat.
Old Mar 28, 2012 | 02:23 AM
italiandominator's Avatar
italiandominator
Look on craigslist or a junkyard, most of them will fit from different years. I was able to get the leather seats from a laramie, after I stripped everything down...the frame and cusion were exactly the same, only difference was the covers.
Old Mar 28, 2012 | 06:02 PM
Reject's Avatar
Reject
Wow I can get my whole front redone, custom, for $600ish, And that includes the center jumpseat
I got a quote as I wanted to get mine redone in Black/Blue Stitching as my Pass. Seat has a tear in it (Small)
Old Mar 28, 2012 | 09:01 PM
EliteTempleton's Avatar
EliteTempleton
Question
Are those heated too? !
Old Mar 29, 2012 | 04:26 PM
graythang's Avatar
graythang
Yes I change my left seat cover and foam bolster. I have the crappy factory Laramie leather seats. It is quite easy to change the bottom seat cover and cushion. The seat comes out with four seat frame to floor bolts. Unplug the power seat wire/heated seat wire and the seatbelt senor wire. No special tools needed just some carful removals and install separating the clips that hold the covers on. It took me about just over an hour to do.
Old Apr 3, 2012 | 08:57 AM
italiandominator
Yeah the ones I got came with the heater elements attached to the cushion...thing is you need the wiring harness and switch to use them, not cheap from the dealer, so hopefully I can find a junked dodge vehicle that has them.
Old Apr 4, 2012 | 01:22 PM
sdsdsd's Avatar
sdsdsd
Thanks for the info, ordered the lower seat cover from
http://www.mmaautoparts.com/nsearch....30495101927010
$118.00 plus shipping. It was $166.00 @ dealer
