If this doesn't fix the squeak I dunno what will.
Old Apr 3, 2012 | 06:28 PM
Holbrook.Jeremy's Avatar
Holbrook.Jeremy
Default If this doesn't fix the squeak I dunno what will.
Tie rod for drivers (Just replaced passenger side 2 months ago)
2 Upper control arms
2 lower ball joints
2 struts
2 strut mounts
2 shocks
all new sway bar end links in the mail
and a transmission cooler for the new transmission.
If I still have the clunking squeak from the front end after this I give up and will drive it till whatever is squeaking dies.
Old Apr 3, 2012 | 07:03 PM
Man I sure hope this fixes it.....
Old Apr 3, 2012 | 11:19 PM
projektdirtfab's Avatar
projektdirtfab
you can keep replacing your tie rods with crappy moog ball joint parts and it will continue to squeak and clunk over bumps lol
Old Apr 4, 2012 | 12:24 AM
ReturnToSender's Avatar
ReturnToSender
Did you change your front sway bar bushings?
Old Apr 4, 2012 | 01:12 AM
FrenicX's Avatar
FrenicX
You won't need those control arm bushings. The uppers come with them, and they are far too small to be lowers, unless they are lower strut bushings, in-which case I need to know where the F you got those cause I looked everywhere!!
listen to that salesman lol.
Old Apr 4, 2012 | 01:17 AM
projektdirtfab
they sure look like strut bushings....the uppers in the picture have bushings in them already....and if they were for the lowers...wouldnt there be 4?
Old Apr 4, 2012 | 02:10 AM
projektdirtfab
haha hey hey....im not selling anything! just friendly advice because i keep hearing people with balljoint tie rods loosing the socket and spinning into a ditch is all. more of a safety concern
and because people keep complaining about replacing junk parts....with more junk parts.
Old Apr 4, 2012 | 05:55 AM
Holbrook.Jeremy
Those spare bushings are further proof that I'm an idiot, I didn't read close enough on rockauto and thought they were for the lower arm (Also thought they were sold in pairs). All the sway bar stuff is coming but the "squeak" in the front end is metallic sounding so I'm assuming/hoping ball joint. projektdirtfab I simply couldn't afford your setup when ordering everything, I just had to replace the transmission and still have this infuriating squeak to deal with. Unless I can get the setup rent-a-center style!
Old Apr 4, 2012 | 07:04 AM
NickM's Avatar
NickM
I just fixed my clink this week by replacing the sway bar links and I was left with a squeek but wd-40 on the sway bar bushings took care of that.
Old Apr 4, 2012 | 09:47 AM
Hokie John's Avatar
Hokie John
I thought the greasable Moog problem solver front end parts were the best available? What parts would be better to use?
