Header installation inquiry
Old Apr 19, 2012 | 03:47 PM
mikeg87xx's Avatar
mikeg87xx
Can you send me a link for a Y-Pipe thatd fit that doesnt have as much restriction as the stock? and what if i put the headers in and a new Y-Pipe?
Old Apr 19, 2012 | 08:06 PM
Alfons's Avatar
Alfons
If you're going to use a Y, I'd recommend the OEM Y pipe as it is, connected to the catalytic converters. Adding a large diameter pipe won't necessarily help, in a lot of cases it will hinder because the gas expansion and greater surface area of the pipe will cause the exhaust to cool too quick, slowing it down - this will cause a constriction, holding back the hot gases trying to make their way out. If you're looking at a set of headers, I'd recommend dual exhausts with the following configuration on each side - header, cat, exhaust pipe, X style crossover pipe, muffler, tailpipe. Pipe wrapping helps as well. There are quite a few fairly detailed writeups on the internet that can give you the basics on making a V8 exhaust.
Old Apr 20, 2012 | 02:29 AM
FrenicX's Avatar
FrenicX
http://www.amazon.com/Magnaflow-1075...4903263&sr=8-1
Here's the one the fits the stock 2.25x2 to 2.5
Old Apr 20, 2012 | 07:08 AM
mikeg87xx's Avatar
mikeg87xx
nice, but what Alfons says makes sense as well. Now I have some decisions to make...
Old Apr 20, 2012 | 07:37 AM
my 2 cents, if your installing headers, might as well run true duals with the cross over, etc. Do it the right way to maximize the potential. Don't think you'll notice much of anything except sounding really cool.
Old Apr 20, 2012 | 08:42 AM
mikeg87xx's Avatar
mikeg87xx
And also put the Magnaflow Y-Pipe in?
Old Apr 20, 2012 | 09:04 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Good info man! This has been discussed before and no one ever believes this idea. I am in agreement with you!
Old Apr 20, 2012 | 04:23 PM
mikeg87xx's Avatar
mikeg87xx
I was talkign to a mechanical engineer and he said put the headers on, keep the stock cats and Y Pipe with the true dual setup in an X-PIPE fashion. He said i can put the hi-flo cats in but then i need to worry about MA State Emissions,
Old Apr 20, 2012 | 06:11 PM
FrenicX's Avatar
FrenicX
yea I'm wondering if mine will throw any emissions codes, I've heard the 4.7 pcm is kinda a stickler for 02 readings. I'll probably try the spark plug fouler trick if I have any.
Old Apr 20, 2012 | 08:19 PM
Alfons's Avatar
Alfons
I'm not sure what that really means. I agree with keeping the stock catalytic converters, but if you also keep the Y, then you you certainly don't need a crossover of any kind and you won't have a dual exhaust. Perhaps you misunderstood him. I'd recommend asking him to draw you a picture of what he's suggesting.
