Rear bumper from Rockauto
Has anyone ordered a rear bumper from rockauto? These are the choices but its kind of hard to tell what you are actually getting.... I need just a regular black rear bumper. Mine is starting to rust. I guess primer would be ok and I could spray it with bedliner or something?
Just clean it up and repaint it.
I cleaned the rust off mine best I could, applied Rust Inhibiting paint, Self-Etching Primer then Bedliner.
Well your at it clean up under your truck with it off, I put on some rubberized under coating on the Hitch and such
I found the cheaper stuff worked better, Altho the primer isnt to cheap lol
https://dodgeforum.com/forum/3rd-gen...p-plastic.html
If you can get the hardware and brackets off, Get the cheap one. But it doesnt sound like it comes with the brackets that are inside the bumper. I assume they are the Brackets, Since it bolts directly to the support bar, or Factory Hitch.
If you look at my pics you can see the one im talking about, held in with 3 bolts each.
I coated the 4 that hold it to the Hitch/Support Bar in PB Blaster and was able to get them off the same day with a breaker bar, There is no bolt to hold, the 2 on each side are welded to a plate together so the dont spin.
Trending Topics
Probably looking at $75-$100 for shipping, but if youre willing to pay for shipping I could get it boxed up and to FedEx. The bumper shell has just been sitting in the basement. I was rear ended in November of 09, the bumper was replaced with a genuine Mopar bumper, and I replaced the bumper with the roll pan a year later.
Good Luck.
