LED lights
Old May 31, 2012 | 12:15 AM
  #31
KingsDodges's Avatar
KingsDodges
wat are the numbers i should look for wen choosing the dome lights?
like size and brightness?
Old May 31, 2012 | 03:59 AM
  #32
marcsnyder05's Avatar
marcsnyder05
Go to (super bright leds.com) and put in your truck info they have all the info
Old May 31, 2012 | 10:51 AM
  #33
KingsDodges
Thank You
Old Jun 1, 2012 | 10:41 AM
  #34
Moltenburn's Avatar
Moltenburn
So another update to my LEDS that I purchased from Super Bright. The T10 wedge bulbs I bought for my license plate lights were the culprit in regards to my driver side driving lights fuses that kept blowing. Not sure why but these caused a ground in my electrical that would blow the fuse when I turned on my parking lights?
It is not clear why but once we pulled them put back in regular bulbs no more blown fuses. I tested both LEDs with a nine volt battery and they both lit up. Not sure why these were totally fuhking up my electrical in the truck. It took multiple hours and a very savy tech to help me figure out the issue. But be forewarned these may not be worth the price of admission, mine are going back today.
Old Jun 1, 2012 | 11:05 AM
  #35
06Dak4.7Silver's Avatar
06Dak4.7Silver
They are polarity sensitive..but if they were lighting up on your truck then they were connected properly. If they did not work on your truck then you had to turn the bulb 180 degrees and plug it back in.
Old Jun 1, 2012 | 11:09 AM
  #36
novovictus1's Avatar
novovictus1
I have the super cheap china LEDs in my license plate sockets as well. I had them in my last car, and in this one for almost a year. No blown fuses or any issues yet.
Old Jun 2, 2012 | 10:46 PM
  #37
Corks's Avatar
Corks
i got mine from v-leds. the interiors are blue and i got blues in the cargo lamps. Those have a tendency to stay on lit very dim while i drive but nothing bad. im looking into the 3rd brake light bulb and i'm looking at adding mre lights to the tails
