engine idle stumbles, engine stalled
I replaced the IDLE AIR CONTROL valve O rings (one was broken) and cleaned and checked the valve, cleaned the throttle body and I still have a stumbling idle and when I started out of a parking space, the engine quit. It started right up again and runs fine but this irratic idle is making me crazy. Truck is a 4.7 liter v-8 with 50k miles on it. It just runs good except for this issue. Is there an electrical check I can make on the valve?
The 2000 Dakota I had before my 05 had the Crank Sensor go in it, Causing it to idle rough and stall out unless it was kept at ~1000 RPM. It would die especially when braking/stopping.
It was a V6 3.9l auto tho.
Thats the only think I can think of, But I have not been tinkering with Cars to long only like 2yrs so. Someone will chime in with other things it would be.
