Engine Miss at Speed
Old Jul 2, 2012 | 08:29 PM
  #21
Deer Hunter's Avatar
Deer Hunter
I feel it on a flat. The slightest acceleration or deceleration and it goes away. Also, I think it happens above the 50 mph threshold but I just don't feel it. Kinda like a lawnmower, at a lower throttle the handle shakes alot and as you raise throttle it turns from shake to vibration. I seldom use a/c, but the other day I had it on and noticed I could feel that stutter more. At 65 mph(w/ac) I thought I could still feel it at a higher cycle rate. Just not sure if it was real or imagined (lol).
Old Jul 2, 2012 | 10:41 PM
  #22
JimBio's Avatar
JimBio
If it was a bad coil it would show misfire codes and you would have a soggy black spark plug over time.
Your not imagining things, I can hear the surge in the AC blower when it acts up.
Old Jul 3, 2012 | 12:46 AM
  #23
erau's Avatar
erau
Are you guys sure it's not just the sudden loss of power when the A/C compressor clutch grabs? The clutch may not be as smooth as it used to be.
Does it happen with the A/C system completely off (not even on defrost)?
Old Jul 3, 2012 | 06:45 AM
  #24
wuzfuz's Avatar
wuzfuz
I read some where and now can not find that read, where someone dismantled their transmission and found a spring on something inside had come off. Not sure why they were doing trans work to begin with. I dont feel my miss on acceleration only at steady speed above 35, yes could be the trans like it wants to finish a shift or can not figure which gear to be in. I have put in tow/haul and without this , no change other than the tach read different higher rpm with in.
Old Jul 3, 2012 | 06:48 AM
  #25
wuzfuz's Avatar
wuzfuz
ERAU... My miss is with and without the AC
Old Jul 3, 2012 | 10:16 AM
  #26
erau's Avatar
erau
That's going to be a tough one then. Not sure I'd want to spend the money to tear into the transmission just on a guess when everything else about it is working fine...They're generally best kept well enough alone if they're not indicating any definitive problems.
It may be best just to wait until it gets bad enough to throw a code.
Old Jul 3, 2012 | 12:32 PM
  #27
Deer Hunter
Did you read that info on this forum?
Old Jul 4, 2012 | 06:06 AM
  #28
wuzfuz's Avatar
wuzfuz
NO Cheeseburger I am not this guy...
Old Jul 4, 2012 | 06:47 AM
  #29
wuzfuz's Avatar
wuzfuz
I have been looking at so many forums and sites and trouble shoot locations, I really dont know where I read it. I would like to find a real pro that knows dodge trans that may know about this spring thing. I am looking around Springfield Mo now to find this person. I did talk with the trans guy at only dealership here about my problem, he had never heard of this going on. This Dodge is my first Chrysler product, so now have to find this membership family that know all.
Old Jul 5, 2012 | 02:53 PM
  #30
Deer Hunter
I'm going to replace the TPS and see what happens. It could be bad and sending a false a signal to PCM and/or trans causing them to react to an improper throttle position. This would affect shifting, timing and fuel injection duration.
