Anyone have the TSB for the software upgrade for transmission
Old Jul 16, 2012 | 08:20 PM
08_Dakota's Avatar
08_Dakota
Default Anyone have the TSB for the software upgrade for transmission
Hey Everyone,
I was wondering if anyone knows where to find the TSB or whatever to show that the software needs to be upgraded for the Dakota 3rd gen transmission shift upgrade? I want to take my truck in wednesday and have them do it. Do I need to show them proof that this is needed? Do i just ask for it??
Truck downshifts too much when going down hills and stuff.
Thanks
Old Jul 16, 2012 | 08:29 PM
jasonw's Avatar
jasonw
Site Moderator
I don't think there is TSB for a software upgrade for 2008+ transmissions in Dakotas. There are for 2005-2007 with the older V8s. I will research.
EDIT: The only transmission related technical service bulletins I could find for the 2008 model year dealt with shuttering of the torque converter/transmission, nothing to do with shifting. Where did you hear there was an software update?
Old Jul 16, 2012 | 09:23 PM
Eimer123's Avatar
Eimer123
Dodge forum has added a TSB search to the forum
It is located in the black bar at the top of the page.
https://dodgeforum.com/forum/alldata...011/makeid=16/
Old Jul 16, 2012 | 10:23 PM
dakotaff's Avatar
dakotaff
I'm not seeing any TSB's for the 08+ transmission either.
Old Jul 17, 2012 | 07:07 AM
08_Dakota's Avatar
08_Dakota
What was with the shuttering? How do I know if mine had been serviced for that one? Should I mention it to the dealer?
Old Jul 19, 2012 | 04:51 PM
rodslinger's Avatar
rodslinger
Default From the NTSHA.gov website
I actually have a 2011 and had a TCM flash a few months back for same issues. Helped a LOT.
Make : DODGE
Model : DAKOTA QUADCAB 4X2
Year : 2010
Manufacturer : CHRYSLER GROUP LLC
Service Bulletin Number : 18-011-12
Date of Bulletin : MAR 15, 2012
NHTSA Item Number : 10044182
Component : POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM)
Summary :
CHRYSLER: FLASH: MIL ILLUMINATING WITH TRANSMISSION AND DRIVEABILITY IMPROVEMENTS. THIS BULLETIN INVOLVES FLASH REPROGRAMMING THE POWERTRAIN CONTROL MODULE (PCM) WITH NEW SOFTWARE. ALSO INCLUDED MODEL RAM1500 MODEL YEAR 2010 AND MODEL DAKOTA MODEL YEARS 2009-2010. *JS
Old Jul 19, 2012 | 05:02 PM
smitty21's Avatar
smitty21
dodge also did it to my pcm to... it helped a bunch.
Old Jul 19, 2012 | 05:42 PM
BBoSS's Avatar
BBoSS
How does one check their dakotas vin too see what TSBs need to be done.. i too notice some shuttering in my tranny. but i also wonder if theres other ones that i need to have done..
Old Jul 20, 2012 | 01:49 PM
DodgeCares's Avatar
DodgeCares
BBoss,
Are you talking specifically about the trans? If so, I can look up the TSB's for you if you PM me your VIN and symptoms.
TSB's are typically performed based on symptoms of malfunction by the vehicle. Chrysler pays for a TSB if the fix is under warranty but only if their was an original complaint from the customer. If you are just looking to get any TSB done to your truck that may apply you would be looking at numerous fixes resulting in thousands of out of pocket expenses since no warranty would apply.
Old Jul 20, 2012 | 03:34 PM
Yep, TSB's are only free if your still under warranty. Otherwise it will cost you. Not the same as a recall.
