Old Aug 13, 2015, 05:49 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
How To Install Parking Sensors on our trucks
Old Jul 18, 2012 | 08:37 PM
Moltenburn's Avatar
Moltenburn
Default How To Install Parking Sensors on our trucks
First off I will post full pics of the truck once it is washed, the beast is filthy. Second please no comments on the smudged primering it is temporary I am going to 3M(line-x) my bumper in a few weeks.
So I bought this kit off of amazon. It is a very nice kit for $31 smackolas. It has a nice compact display that shows where the object is and how far off you are. Easy to see in the day and has a mute switch if you get tired of the beeping. There alas is no volume control.
Amazon Amazon
Good overall kit, But be forewarned, the drill bit it comes with licks the as-s-e-s of a million monkeys. That being said go buy yourself a good 7/8ths bi-metal hole saw. Also test your kit w/ a 9-volt battery before installing. You want to make sure all is well before going to town.
First you need to pick your spots. I chose to have mine on the far ends 1" down and 3" over from the molding marks on the plastic caps of the bumper. Then decided to mount the inners 2" down and abut 7" from the licenses lights. I used masking tape and sharpy to set my points for the drilling. Now measure once, twice, three, four... hell you get where I am going with this, because once you unleash a drill on it you are in full D-ick-s.
So once your comfortable with your placement use a hammer and a center punch to set your drill points, you do not want your bit wandering. Once that is a go take a deep breath and start hole sawing you sh-it. You should end up with this.
Four nice holes symetrical to the center point of your bumper. Now remove your tape, use a file to smooth any edges, apply auto primer to your edges (no rust) and install your sensors in the bumper. When you get them you will see that they have a way of being put in that points them ever so slightly towards the ground.
Followed by bundling them as needed and running the wires how ever you like in the rear assembly of the truck. I zipped tied the ish out of everything and utilized the driver rear backup light for my power source.
Now lets test everything out again plug in sensor unit and alert screen, then hook up your 9 volt. With screen in hand walk back and forth in front of your bumper at different lengths. Does it read correct? Yes? Then you are friggen awesome parking sensor install ninja deluxe. Deluxe Son, Deluxe.
I did not grab photos of the wire tap install I am sorry and a bit drunk by this time. Your reverse has a white (positive) and a brown (ground) wires. Use radio shack taps with a pile of electric tape. Reminder it gets dirty in that light area. From there Stick the control unit to inside panel of truck fender w/ double sided tape. My kit came with it. Plug everything in and put truck in reverse (not running for those dumb fuhks out there) and it should work just as previously tested.
For adjusting the sensors you can turn them a little left or right with out screwing with the downward angle. Pick and chose as you please.
Now for the display I ran mine from the small cubby hole behind my cup holder to the control unit in the rear. Mine came with a 16ft cable which was barely enough to reach but did make it there. The trip to this is finding a entry hole to the cab. I found by pulling up kicker panels we have small white plugs, perfect for pulling out, routing wire, and re installing.
I routed the remaining wire towards the rear through numerous frame holes and zip tying. From there routed remaining wire and display through the cabin used double sided tape to attach out of the way and viola. We are done here friends.
To finish I did end up hiding all wirings with ease and there are numerous ways to do so if you like. A week in and they are still working sweet no issues. I will post picks on my profile post once the truck is clean.
Cheers
Moltenburn.
Old Jul 18, 2012 | 10:43 PM
BBoSS's Avatar
BBoSS
Nice!
Old Jul 18, 2012 | 11:30 PM
erau's Avatar
erau
Badass. I like that, great job.
Old Jul 19, 2012 | 09:18 AM
northgator8's Avatar
northgator8
I agree, great write-up and install, but we have big steel bumpers so why do you need back-up sensors? Drive by brail, man!
When you feel an obstical, you are there! LOL
Old Jul 19, 2012 | 11:01 AM
Nice write-up! I put a set of these in my daughters mustang and my wifes journey because they are constantly backing into crap. Me, I just use my mirrors...
Old Jul 19, 2012 | 01:27 PM
DakotaAgain?'s Avatar
DakotaAgain?
Way too much work for something I never thought I needed, but if you like it , enjoy.
Old Jul 19, 2012 | 04:18 PM
FrenicX's Avatar
FrenicX
If my wife drove my truck, I'd definitely need a set of these.. but she's afraid of it so no worries lol.
Old Jul 19, 2012 | 04:40 PM
Moltenburn's Avatar
Moltenburn
Thanks for the comments. Yeah I know how to drive but its D-Bags that will pull out behind me in grocery stores that drives me nuts. Once I added the topper I knew I needed some extra coverage. Plus my stocker Dak gets a bit more neato.
Old Jul 19, 2012 | 06:46 PM
Eimer123's Avatar
Eimer123
I will save myself the money and continue to use my hitch to tell me when I am to close to the vehicle behind me. LOL just kidding, but I have bumped some cars before with the hitch.
They call them bumpers for a reason.. to bump
Old Jul 20, 2012 | 05:32 PM
norma jean's Avatar
norma jean
Speaking of mustangs, I'm in myrtle beach now I am seeing more mustangs per square mile than I've seek total in my life, I'm talking countless mustangs I just saw 5 out of 6 cars as them, can you enlighten me why the south loves them soo much?
