Front Sway Bar End Links
Old Sep 12, 2012 | 12:22 AM
kevdadi's Avatar
kevdadi
Default Front Sway Bar End Links
Hello-
I've got a 2006 Raider / Dakota...
Curious to know if there is a cheaper way to rebuild the front sway bar end link kit? Noticed that RockAuto has a cheap pair of end links for $32 shipped to my door, or else Advanced Auto is selling MOOG for roughly $30 each before coupons.
The lower bushing is shot- is there a simple rebuild kit available for this? Looks like the rubbers have simply deteriorated. Have any of you done it?
Thanks for your help!
Kevin
Old Sep 12, 2012 | 01:23 AM
marcsnyder05's Avatar
marcsnyder05
There isn't a rebuild kit just get the moog greasable ones
Old Sep 12, 2012 | 09:57 AM
kjpark's Avatar
kjpark
like marcs said moog, moog is the way to go for us. Or you can get rid of the sway bar all together. I drive without the front one, never have to replace end links
Old Sep 12, 2012 | 01:27 PM
JoeyDMG's Avatar
JoeyDMG
I snapped the end bolt on mine and the grease started leaking out. I'm willing to bet the joint is bad if it's not greaseable. I got a Raybestoes Pro Grade stabilizer link it seemed to work well. It's greaseable as well. I also have the mevotech one which doesn't have wrench flats, so I don't recommend it.
Old Sep 12, 2012 | 02:06 PM
Greasable sway bar end links? Never knew those existed...greasable sway bar bushings and ball joints/tie rods, yes...but the end links? Where would a grease fitting go on the end link?
Old Sep 12, 2012 | 02:54 PM
marcsnyder05
Right here
Old Sep 12, 2012 | 03:47 PM
Well I'll be!! Thats pretty awesome! I forgot about that end....I was thinking it just had two bushingson each end like the top part...lol...how quickly the memory is fading....
Old Sep 13, 2012 | 08:40 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
That's age Kent...
Old Sep 13, 2012 | 09:44 AM
Originally Posted by lghtngblt02
That's age Kent...
Who are you?
