MyGig question
Old Dec 26, 2012 | 06:37 PM
Racinartist's Avatar
Racinartist
Default MyGig question
Real quick, do any of you know if any Chrysler MyGig will bolt right up in in 3rd Gen without modifying the wiring harness, plugs, etc?
Thanks
Old Dec 26, 2012 | 09:59 PM
Reject's Avatar
Reject
I think most Use the same Wiring Connector, But it also depends on the Year of the Dakota, and Year of the Part.
Also I think if you have a stock radio, some features might not work, like GPS, Sat Radio, Ect. Not sure.
2005-2007 Dakotas have the ***** on the Side
2008+ Dakotas Removed the *****
I know other Vehicles also had the *****, My brother 2008 Compass did and others it was removed after aswell
05-07
08+
Old Dec 27, 2012 | 09:21 AM
Racinartist
Yea mine's an 08, so the face plate isn't an issue. I just don't know if the wiring and plugs are interchangeable. I also know from some people who own Durangos that their speakers are wireless. Does anyone know if that's the case in Gen III Daks too, or is everything hard wired?
Old Dec 27, 2012 | 06:17 PM
dodgetrucker75's Avatar
dodgetrucker75
in the 08 the mygig is plug n play, but you have to have a low speed bus mygig, a high speed will not work in the dak
here is mine i had
Old Dec 27, 2012 | 07:15 PM
Racinartist
This one came from a Chrysler 300. After a quick search, it appears those are a low speed bus setup. So hopefully it will work. It has no nav but idc about that.
Old Dec 28, 2012 | 01:19 PM
dodgetrucker75
i just put a non nav in my ram, i like it, the only thing that kinda sucks tho is no bluetooth/uconnect, it has to be added on, (witch i did) much cheaper to buy the nav unit if you want bluetooth, i would also recomend the lock pic too, you can have dvd in motion, back up cam, a/v input and out puts, i had mine set up with digital tv channels, and the abilty to hook up the PS3, it was pretty fun
Old Dec 30, 2012 | 09:18 PM
clayh's Avatar
clayh
I added the the mygiglockpick to the wife's '08 Dakota. It was the only way to add an interergrated backup camera. Also upgraded and got the full Iphone integration as well.
http://www.coastaletech.com/MYGIG.htm
Old Feb 1, 2013 | 09:34 AM
trotterp2305's Avatar
trotterp2305
Here is where i when for mine gives you instructions and has all the accessorizes.
http://www.google.com/url?sa=t&rct=j...41867550,d.cGE
