Full-sized double din in my 2006 Dakota
Old Jan 12, 2013 | 05:33 PM
faynce's Avatar
faynce
Default Full-sized double din in my 2006 Dakota
Here it is, folks. Did the custom work myself.
I'm not a professional, as you can probably tell.
Erik
Old Jan 12, 2013 | 08:17 PM
Anthony Grego's Avatar
Anthony Grego
thats pretty good can u send me the dimentions of the new cut space (overall Width and Height, and height from the top of the **** spaces to the top of the cut under the vents)
im bout ready to do mine but wanna have someting to go by so i dont totally F mine up.
Old Jan 12, 2013 | 09:19 PM
faynce's Avatar
faynce
I don't recommend measurements, especially since the fronts of all headunits are different. I recommend trimming a small amount from the radio dash plate a little bit at a time with a very sharp wood chisel. That's what I did.
If your unit is as large as mine, you will also find the space inside the dashboard isn't large enough to fit the unit inside.
Erik
Old Jan 13, 2013 | 12:21 PM
dakotaff's Avatar
dakotaff
Looks like a good job, enjoy.
And out of curiosity, which model radio is it?
And Welcome to DF.
Old Jan 14, 2013 | 06:53 AM
faynce's Avatar
faynce
It's an Eonon G2103U, a Chinese headunit.
http://www.ebay.com/itm/280899650724...=STRK:MEWAX:IT
Old Jan 29, 2013 | 02:15 PM
cheeseburger's Avatar
cheeseburger
How did you mount it to the dashboard? and what did you have to cut out to make it fit?
Old Jan 30, 2013 | 07:39 AM
faynce's Avatar
faynce
I had to take a reciprocating saw and cut out the entire plastic shelf the original radio sat on. I left the mounting screw holes in place, as they fit any universal mounting kit.
The back of the larger radio just barely sits on top of the main structural beam that runs through the back of the dash. I put a shim between it and the bottom of the radio.
The thin plastic piece that sits between the radio cavity and the vents also had to come out.
Old Jan 30, 2013 | 08:34 AM
cheeseburger
Thank you very much for the info, It is much appreciated.
Old Oct 23, 2015 | 03:53 PM
rkircho's Avatar
rkircho
Default 2005 Dodge Dakota Alpine INE W960 Install
Nice job. I am getting ready to buy the Alpine INE W960 Nav unit for my 2005 Dodge Dakota? The dimensions are 7x315/16x61/2. Would the 6 1/2 inch depth fit in the cavity? Thank you
Old Oct 24, 2015 | 08:17 AM
dakotaff's Avatar
dakotaff
I see that that unit posted above, Eonon G2103U, has a depth of 6.69 inches (170mm), so you should be good with your Alpine INE W960 (165mm).
Welcome aboard.
