getting a soft cloth tonneau cover for free, but..
Old May 3, 2013 | 09:53 PM
FrenicX's Avatar
FrenicX
Default getting a soft cloth tonneau cover for free, but..
It's from a 2004 quad cab, and I'm not sure if they changed the dimensions of the bed from gen 2 to gen 3. I know that a hard top cover wouldn't work because the outside dimensions of the trucks did change, but did the inside measurements change at all? I'm not sure what brand it is, I'll be picking it up monday.
I looked online at another brand of soft cover, and found that the part number was the same for 04- and 05+, so maybe there is hope.
Any insight would be greatly appreciated, thanks guys.
Old May 3, 2013 | 10:53 PM
Deer Hunter's Avatar
Deer Hunter
When I got mine in 05 I had to wait for it to be manufactured because the 05 bed has a taper to it. Wider in the rear I believe.
Old May 8, 2013 | 10:40 AM
ixl4's Avatar
ixl4
it should work, but it will sit narrower by the cabin and wider in the back.
Old May 8, 2013 | 04:56 PM
Reject's Avatar
Reject
This, The inside of the Box is the Same, Rail to Rail and Front to back. Also is the same on Gen 1's. As I had a guy with a Gen 1 buy the Cap off my Gen 3, which was a Gen 3 Aluminum Cap with Rear Doors It fit perfectly on his truck
Old May 9, 2013 | 09:33 AM
My soft cover frame had different width cross bars because the outside of the beds are narrower at the back. If the one your looking at has a frame, I would check the fit first. IIRC, the side rails clamped to the top of the bed sides and the cross bars snapped in and you could not interchange the positions. True, the inside bed dimensions are the same, but the frame of the cover sits on top of the bed rails, not inside; therefore, it may not fit right.
Old May 16, 2013 | 11:01 PM
FrenicX's Avatar
FrenicX
An update on this, I got the cover and it does rest on top of the bedrails. The clamps are on the inside and clamp nice and tight. The only thing is, as was mentioned, the taper from the cab to tailgate is around 1.5" difference, but it's not ugly at all. Looks good in fact, I will get a couple pics soon.
Old May 17, 2013 | 07:57 AM
Allow me:
Old May 22, 2013 | 02:19 AM
FrenicX's Avatar
FrenicX
once I get a good wash done, I'll postify. I sanded and buffed out my yellow headlights too, they look brand new!~
