3.55 lsd
Old May 26, 2013 | 08:56 PM
mrwhatshisname's Avatar
mrwhatshisname
Default 3.55 lsd
does anyone make a LSD 3.55 diferential for the dakota?
Old May 27, 2013 | 02:40 AM
Neil Hall's Avatar
Neil Hall
yup.. just installed one the other month in mine.. 31 spline is what u need. the ring gear and abs ring transfer over..
Old May 27, 2013 | 10:26 AM
jasonw's Avatar
jasonw
Site Moderator
Going to have a shop install an Auburn LSD into my 3.55 rear end one of these days. The Auburn is sitting in my garage still, just waiting.
Old May 27, 2013 | 10:43 AM
superdak05's Avatar
superdak05
if your going lsd, change out those 3.55 to 4.10, you wont be disappointed at all
Old May 27, 2013 | 08:45 PM
mrwhatshisname
if I change it to 4.10 then I have to do the front also. I only want to do one axle.
Old May 27, 2013 | 09:10 PM
moe7404's Avatar
moe7404
changed my 2001 dak from 3.55 to 4.10. with a 3.9 V6 auto trans. i drive in town only, and my MPG went from 8-9 MPG to 11-12 MPG cause it let my O.D. come in at 35 MPH. NOTE: in town only.
Old May 28, 2013 | 08:42 PM
jasonw's Avatar
jasonw
Site Moderator
Sure, if you have an extra $2000-$3000 lying around, since 4x4s require both axles to be changed.
Old May 28, 2013 | 09:50 PM
donkeypunch's Avatar
donkeypunch
King Jackass
What rear end to you have? 8.25" or 9.25"? You can purchase factory LSD units from randys ring and pinion. Or, drop in a better unit like the the Auburn or Eaton.
Old May 29, 2013 | 01:19 AM
sleds's Avatar
sleds
Just do the front yourself. Here's a link for you when I did my 4.56 gears.
https://dodgeforum.com/forum/3rd-gen...ar+change+pics
Old May 31, 2013 | 10:23 PM
FrenicX's Avatar
FrenicX
I'm kinda disappointed with my Auburn lately, maybe I need a fluid change but it doesn't seem to be as tight as it was when it was new. It will still keep 50/50 power transfer in a straight line, but cornering almost feels "open" anymore. It will spin 1 wheel in a turn if I let it. When it was new, (12k miles ago) it was tight, and almost reluctant to allow the wheels to spin at different rates when cornering. But then again, maybe it's just the way it should feel when it's worn in.
