transfer case
Old Aug 2, 2013 | 12:06 PM
superdak05's Avatar
superdak05
Default transfer case
trucks 4wd service light came and tried dropping it into 4 lo around 70 mph today, what a scaring thing to happen, pulled off highway and shut off truck, waited a few minutes, fired it up and away I went, guess it's time to change the fluid and the transfer case switch
Old Aug 6, 2013 | 01:42 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Any updates /diagnosis on this man?
Old Aug 6, 2013 | 03:45 PM
FrenicX's Avatar
FrenicX
This is how I justify not having 4wd, it might try to kill me some day! Hope its going ok for ya
Old Aug 6, 2013 | 04:20 PM
Alfons's Avatar
Alfons
There is a safety algorithm built into the PCM program that even with a selection to 4Lo, it won't even try to shift if the conditions aren't right. The Owner's Manual gives you the criteria that will allow the shift to happen - this protects the truck as well as it's occupants.
Old Aug 7, 2013 | 12:12 AM
Tom A's Avatar
Tom A
Section Moderator
I still like having the old-fashioned shift lever so I'm in control of when it shifts, not some algorithm.
Old Aug 7, 2013 | 10:11 AM
06Dak4.7Silver's Avatar
06Dak4.7Silver
That's some scary **** guys..hope your truck isn't mad at you superdak. Man, I barely use 4wd. Only in snowstorms and what not although I plan to have some fun with my Cooper ATIII's when take the 20's off in a month
Old Aug 7, 2013 | 10:22 AM
Alfons's Avatar
Alfons
I agree, the manual shift is a lot more reliable & simpler, and if you wanted to blow up the t-case with a stupid shift, you had that opportunity - it was your decision. I think "idiot proofing" has really gone too far and gets really expensive to fix when it fails. In most cases you can't revert to "simple" any more.
I use the Dana 300 on my Jeep, it's almost bullet proof.
Old Aug 7, 2013 | 08:29 PM
Tom A's Avatar
Tom A
Section Moderator
I have an NP205 in my Blazer.
Old Aug 8, 2013 | 02:03 AM
FrenicX's Avatar
FrenicX
I have the GetOutAndPush in my dak, its a multimode transfer case, sometimes it's a FlagDownA GuyWithA Towstrap
Old Aug 8, 2013 | 08:56 AM
Alfons's Avatar
Alfons
Frenic, you have the simplest version of a t-case, you'll never have to put a dime into any repairs
