3.7L Exhaust
Old Sep 11, 2013 | 08:51 PM
Reject's Avatar
Reject
Originally Posted by northgator8
The RCMP might have a discussion with you . . .
And maybe you will be without feedback from the O2 sensor (I think there is at least one after the Y-pipe).
The RCMP wont bother me. It will just would like a Ricer exhaust haha. Plus they are pretty lax here since we have 2yr mvi's (used to be 1yr till last year, Still do on trailers)
Originally Posted by lghtngblt02
Nice! You'll love it I am sure. Sorry to hear about the rapings... lol You should be alright removing the back portion of the exhaust from the first bolted connection after the Y. Its about inline with doors. The O2s are closer to the engine and they shouldnt give you an issue. The MBRP will connect from the stock pipe. If you need anything, let me know. Mine, although a V8 was pretty simple to install besides the end tail pipe support connections, but I fixed that and told MBRP about it. I received some free apparel for it It shouldnt be much different though
The 3.7L and 4.7L Exhaust are the same. (from the Y back) Atleast ive gotten that since every one I looked at said 3.7L/4.7L
Old Sep 24, 2013 | 10:55 PM
Reject's Avatar
Reject
New Exhaust Arrived on Monday, Out of town untill tomorrow night. So far ive removed only the Tailpipe (Muffler Back) last week, Came out easy enough. Bolts at the Y pipe will be my issue.
Old Sep 25, 2013 | 08:32 AM
Just dont drive around too much with the y-pipe removed and your windows rolled up. You'll die.
Old Sep 25, 2013 | 09:59 AM
FrenicX's Avatar
FrenicX
Can't wait to hear this in a v6. Should sound nice. There was a guy on here with flowmaster super 10s on his v6, it sounded really good for a v6 actually.
Old Sep 25, 2013 | 12:42 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
There was one guy with an MBRP V6 but never put up a sound clip.
Old Sep 25, 2013 | 06:35 PM
Reject's Avatar
Reject
It still has the pipe and muffler, I removed the Tail after the muffler.
I also had a work van so it was sitting at work untill a hour ago.
Check the exhaust, it changes it from a 2.5" at the Y to 3", Then 3" in/out.
Comes with all the Clamps required, and a Chrome Tip. (Which is going to be a PITA to get on, since its almost the same diameter as the pipe were it connects.)
Old Sep 27, 2013 | 01:15 PM
Reject's Avatar
Reject
Got my old exhaust off now, Wasnt to hard. Used a dremel to cut the clamp at the Y pipe (since it was installed bolt up) split it apart, then gently and slowly pried the 2 pipes apart.
Now ive run into the issue of MBRP having a male end on there pipe when the Y pipe is male (Old resonator pipe was female) so it doesnt fit together. Anyone know how a quick fit for it?
Old Sep 27, 2013 | 01:32 PM
Reject's Avatar
Reject
Old Sep 27, 2013 | 01:39 PM
FrenicX's Avatar
FrenicX
Whatever you do, don't buttclamp with a band clamp. It will never hold. Your local parts store should have a 2.5" ID butt connector. I used one just the other day on a friends car that I got from O'Reilly's. Then a couple of these should finish the job, from Summit Racing
WLK-33226 2.5" preformed lap joint band clamps. from summit
or Dynomax 33226 from Amazon, same exact part.
Old Sep 27, 2013 | 01:44 PM
lghtngblt02
Originally Posted by Reject
Turn it around? Its backwards? The MBRP pipe that is
They are the clamps that should come with the kit.
File Type: jpg
File Type: jpg
File Type: jpg
