zex nitrous kit?
Old Nov 8, 2013 | 12:48 AM
Neil Hall's Avatar
Neil Hall
Default zex nitrous kit?
hello all, well winter has come and the mod bug has bit me... again... I have been looking into the addition of a zex wet nitrous kit for my truck with the 4.7. anyone have experience with this setup? also the truck has 255000km on it.. is that getting a little high to run nos? thanks.
Old Nov 8, 2013 | 08:37 AM
Superdak is running nitrous. Hopefully he will chime in.
Old Nov 9, 2013 | 12:01 AM
superdak05's Avatar
superdak05
love it, running a 125 shot have a few mods that help out also
Old Nov 9, 2013 | 11:59 AM
FrenicX's Avatar
FrenicX
And you have around 110k miles don't you superdak?
Old Nov 9, 2013 | 01:51 PM
Neil Hall's Avatar
Neil Hall
How much of an improvement in power do you have? What additional mods do you have done? I remember reading that you must run cooler plugs and it's not recommended to be run with a superchips tuner..
Old Nov 9, 2013 | 05:32 PM
superdak05's Avatar
superdak05
currently have 146000 miles on my truck, running the autolite 3922 plugs, 70mm throttle body from the fastman, with a full k/n fipk. iat relocator, cant spray before the iat, biggest gains before the bottle were the 206 cams from krc performance, which I had to tune with a sct tuner by hemifever, no superchips with nos, wont work, swapped out the junk 3.55 with a set of 4.10, peter hany at Connecticut axle did a great job, kept the factory manifolds and went with a larger y-pipe and a single 3 inch catback, tranny is all stock except for my convertor which is a 2800 stall from aps precision. another great mod for cheap is a 180 thermostat
Old Nov 11, 2013 | 12:16 AM
Neil Hall's Avatar
Neil Hall
where did you mount your bottle? and what kind of place would you go to to get it filled?
Old Nov 11, 2013 | 11:33 PM
superdak05's Avatar
superdak05
my bottle is mounted in the bed, I go to allgas to get my bottle filled, any place that sells welding gases normally have nitrous oxide too, fairly cheap in Massachusettes to fill a 10lb bottle, around $32.00
Old Nov 11, 2013 | 11:35 PM
superdak05's Avatar
superdak05
if you click on my photo and go to my albums, you can see how my system is mounted along with the bottle in the bed
