just wondering if anyone has seen this this code before???????
Old Nov 9, 2013 | 04:54 PM
Greatrack2012's Avatar
Greatrack2012
Question just wondering if anyone has seen this this code before???????
2 days ago my truck started showing me this code 9ASCRAP, and I'm wondering if anyone might know this code. I did just change my air filter 2 days before that cod that have anything to do with it? Any help is appreciated thanks
Old Nov 9, 2013 | 05:08 PM
jasonw's Avatar
jasonw
Site Moderator
Its Chrysler for "gascap."
You didn't bump or remove any rubber hoses when you changed the filter did you?
Make sure your gascap is screwed on tightly. If it is, you could try buying a new one (pretty cheap, relatively speaking).
Old Nov 9, 2013 | 05:44 PM
Greatrack2012
No I do don't think I did. But ill check my gas cap and see if that's the problem. I did get gas a few days ago so that might be it. Thanks for the help
Old Nov 9, 2013 | 06:22 PM
Greatrack2012
Ok so I tightend the gas cap ( though it wasn't lose ) and it still comes up. So do I have to hook up a code reader to make it go away or do I have to buy a new gas cap and see if that work's.
Old Nov 9, 2013 | 06:40 PM
dakotaff's Avatar
dakotaff
Disconnect your battery for a bit, then the code will be reset.
Old Nov 10, 2013 | 02:03 PM
Greatrack2012
Well I disconnected the battery and it seemed to have worked . Thanks for the help
Old Nov 16, 2013 | 12:54 PM
sawfish's Avatar
sawfish
Mine did the same thing, and after retightening and resetting a few times. I wound up replacing the cap.
Old Nov 23, 2013 | 02:14 PM
Greatrack2012
That's what I ended up doing, So hoping that fixes things. I also ended up buying a code reader because the check engine light came on. When I scanned it. It said there was a vary small leak/ loose gas cap. But it hasn't come on in a new days now so I think it worked
Old Nov 24, 2013 | 01:17 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
If your CEL comes back check this out... https://dodgeforum.com/forum/3rd-gen...and-p0457.html I just went through it on my 07 after fighting with it for a good few weeks and not being able to find a fix without just swapping parts which would have been pricier.
Old Nov 24, 2013 | 06:13 PM
Greatrack2012
Ok thanks for the link
