Upper A Arm Question?
Old Dec 23, 2013 | 09:12 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Originally Posted by kenttt
I'd go w/the non-greasable.
Here's why: one truck I had (bought new), a non-greasable tie rod end wore out at ~100 K miles, a new greasable one cost more than a non-greasable one. I figured if the original non-greasable lasted 100 K miles why should I pay more for one that I'm going to have to grease ever 3 or 5 K miles?
I replaced both tie rod ends w/non-greasable, drove the truck for another 100 K miles and never had a problem w/the tie rod ends in that time.
YMMV
I went with yourtheory on my tierod ends, I hope it proves the same. The only difference was that my wear outs were at 50k and not 100k, but I blame the roads in the area which were torn to bits from some of the water line upgrades the area was receiving.
Old Dec 23, 2013 | 06:51 PM
Jeremysp1993's Avatar
Jeremysp1993
Originally Posted by dieselpower32x
Has anyone used the Raybestos Upper Control Arms? They are a sealed ball joint but if they will last, I can live with that.
I just purchased mine and have not installed them yet. Looking at them, they look of good quality, looks like oem. Ill be happy if it lasts 75k. Non-greaseable ones are sometimes better. Hell, 99.9% of new cars dont have grease fittings (correct me if im wrong) and they last quite a while.
Old Dec 23, 2013 | 07:58 PM
nanohead's Avatar
nanohead
I don't believe any of the arms are actually greasable. They are press fit... The swivel joints (ball joints, tie rod ends) are the only typical parts that have grease fittings. Not aware of any control arms that actually have fittings anymore, not since the 70s actually.
Its also likely that most are the identical parts, regardless of the "brand" on it. Whether Moog, Raybestos or anything else for that matter. Its probably the OEM that builds it and sells it through various methods of distribution. I doubt that with the low volumes of these trucks sold, that there are that many companies actually still making these parts.
Old Dec 23, 2013 | 11:23 PM
Jeremysp1993
You are correct, thats the only place a greast fitting can be. For all that i know, there are probably control arms for some cars that have a grease fitting at the bushing. My sway bar bushings have grease fittings however.
Old Dec 23, 2013 | 11:40 PM
FrenicX's Avatar
FrenicX
Moog does actually make the parts themselves which are clearly made from a different mold than the OEM stuff, which has TRW branding on it.. if I remember right.
I just cannot stress enough, though... Avoid mevotech for any and all of the swivel/ball parts. The arms themselves are hard to get wrong, but the balljoints, tierods, and end links all have the rubber boot over the ball, this boot will disintegrate in months on mevotech parts.
Old Dec 24, 2013 | 09:26 AM
nanohead's Avatar
nanohead
Yeah, I think TRW (what used to be a huge company!) is still the largest OEM supplier to the major manufacturers for suspension parts. Clearly, they didn't that great a job on our suspension parts
Disintegrating boots is bad! No real way to service them other than taking the whole dang front end apart. Its always the 50 cent part that brings down the best things
