Transmission Strange
Old Mar 1, 2014 | 01:13 PM
05dak21's Avatar
05dak21
Default Transmission Strange
So as I was leaving Cars and Coffee today, something was wrong with my tranny. I drove it there just fine, no issues. As soon as I put it in reverse I knew something had happened. It took a second to go into reverse and then about four seconds to go into drive. It went in with a strong jerk. It wasn't shifting right and second to third was slipping somewhat badly. I had to drive it home and on the highway doing about 60 it tried to go up to third, jolted, and the check engine light came on. I slowly nursed her home in third( it would not go to 4th or 5th after the engine light). Here's the issue. The truck's tranny has only 15K miles on it....help?
Old Mar 1, 2014 | 01:35 PM
rookie's Avatar
rookie
You can only hope that it is something in the shifting mechanism--solenoids or something. That is going to require a transmission shop, or a lot of research and downtime. no help here I know very little about trannies and even less about automatics. I do look at every breakage as an opportunity to upgrade, though. time for the getrag 238 6mt--and an extra left pedal!
Old Mar 1, 2014 | 08:10 PM
What is the code it threw?
Old Mar 1, 2014 | 09:19 PM
05dak21's Avatar
05dak21
They went away after the truck was turned off.I do have a warranty though I had a superchips programmer installed...would it void it?
Old Mar 2, 2014 | 12:39 AM
jasonw's Avatar
jasonw
Site Moderator
It should not void it, but just to make sure, I'd return it to stock programming before taking it into any shops. You can always reprogram it with your tune again after you get it back/fixed.
The CEL may have disappeared, but the code did not. The computer stores the codes, even after a CEL goes out. The superchips (or any decent auto parts store) should be able to read them.
Old Mar 2, 2014 | 02:57 AM
05dak21's Avatar
05dak21
They came back on. Same codes as before. The trucks going in Monday to get looked at, hopes she's back by spring break
Old Mar 2, 2014 | 07:01 AM
What was the code???????????
Old Mar 2, 2014 | 10:21 AM
mlarson29's Avatar
mlarson29
sounds like your low on fluid. my friend had a dodge dakota who had the same thing. it threw up a transmission fault code and it happened to be low as hell on fluid.a top up on fluid about 4 litres solved the problem.
Old Mar 2, 2014 | 12:50 PM
05dak21's Avatar
05dak21
Fluid level actually read hot even when it was really cold. The codes are, P0700: Transmission control system (MIL REQUEST), P0733: Gear Ratio Error in 3rd, P0734: Gear ratio error in 4th, P1790: Fault immediately after shift, P0869: line pressure high, and UO184, lost communication with radio.
Old Mar 3, 2014 | 09:13 AM
DodgeCACares's Avatar
DodgeCACares
05dak21,
I'm sorry to hear about your transmission concern. As you have mentioned, you intend to have the truck looked at this week. A diagnosis would help to pinpoint the direct cause of your issue.
In some cases, a damaged sump filter and cooler return filter may cause similar concerns.
Keep us posted if you can,
