i bent the front of my bed!!!!!
i was moving a job box from site to site it was not very far so i decided not to put straps on but just flip it on it top so the wheels were in the air and some one braked hard infront of me and the box slammed into the front.
any one know how to bend it back?
https://i.imgur.com/qa6Kytn.jpg
https://i.imgur.com/UAZE21f.jpg
Mine was bent like this when I got it, just one crease in it though, not two like yours. My truck was a rental and it didn't have the drop in bed liner. The dealer wanted to put one in and i told him not to, i got remote start instead. I pulled against it slowly until the front of the bed was straight, then I used a hammer to tap down the high spot on the top. There is still a small crease on mine, but you have to know where it is, most of the metal will go back in place if you do it slowly. Tapping down the hight part on top will basically lock in the shape so it won't be too weak in the future.
I would be careful with putting something between the bed and the cab, you don't want to bend the back of the cab also.
Just take your time, don't try to force too much of it at once, and the creases on the vertical parts should lessen dramatically as it starts getting back in shape. Those might still remain, but they might not be that noticeable.
