my 05 slt ext cab audio build up
this will be the total build up of my truck from beginning to end. its not organized in order of beginning to end but its close. ended with the wall of subs gots me kinda loud for what I was going for.
This truck is a daily driver, I spend alot of time behind the wheel, or did when I built this. SO.... I wanted to enjoy what I enjoy, LOUD MUSIC!!! and this is the build up from start to end, started with smaller systems, and built up to this one. and they all were temp systems until all my big stuff got in.
Not sure of the build up just yet, will be a temp system for the time being.
but on to some pics, of the equipment I do have currently.
UHOH>>>> WHATS THIS?
meh potential
this is random, but an electric wheel chair, guy was a speed demon, so he put a redtop on the front to gain speed!
my temp 15.... Prototype.... just for me to be able to say YEP it is!!
looks warped but its just the rubber mounting gasket thats lip was pulled around too much from box removal.
what I call a 2 way setup...
The box. currently its 6.5 cubes tuned at 35 htz with 96 sq inches of port
will hold 2 15's. down the road, but just 1.. for now... maybe 2 dd 9515's on about 4k rms... right behind my HEAD!!!..
45's in every corner.
AND WHAT I'M FIGHTING WITH FOR TEMP.... THIS MAKES THINGS AWEFUL IN A NON AC'D GARAGE AND THIS IS AT 9:30 IN THE MORNING....
MORE PICS LATER WHEN STUFF STARTS SHOWING UP.
meh potential
yezzzzir well finished the buss bar, gonna get pic uploaded soon, as well as the batteries.
here is my wiring under the hood, I have a better battery going in there tomorrow.
well here is where the battery box will go in, BUT here is 2 runs of + and - both 0 awg.
Secondary ground in the back down to the frame.
now, this was the old unit. out with the old
in with the new
and with it playing some Family Guy on dvd
this is the battery box. will be bolted down
Will also probably have a false floor mounted over the battery bank, and mount my amps there. I have a nice tonneu cover that goes on the truck usually. but now that I'm pulling the battery box out to redo it, gotta get it fixed.
what will go into the box. I'm missing 1 more battery that will be here thursday,
they float at 13.2 on current charge.
and this charger is awesome!!!! has a voltage meter on it, and has a battery % charge, and has 3 different setting for different battery types, for standard, gel, and agm, also has a small large and starting setup. also does an alternator amperage output setting.
and was only 75 bucks.
got the voltage meter fixed. and back in
in with the new
well. Got the box full of batterys. and realized.... I won't be able to get all 8 in there....
but mounted the box anyways.... and didn't like it..
here is a few pics of it.
the space I'm working with,
what the box looked like with the batteries installed.
didn't like what it came out to... so started with this,
and this is about 60% finished. the setup will hold all 8 batteries up front, and hold my 2 1000.4's as well as the one Crescendo 3k that will be here on thursday. I will have a plexi window there with some led's inside there. Would have finished this, BUT the weather got REALLY bad... so will continue tomorrow.
How it looks from the back, will be making a beauty panel to cover the back side there, and probably glass in some speakers there on a toggle switch. so when I'm at a show I can chill there. Might add a few things down the road. but for now this is what I have instore.
duh duh duhhhhh... whats this, a message from the delivery man...
MAXXLINK FTW
and... can you say... AWESOME POWER
and... well just didn't like the look of this stuff. so I pulled it out... will take a pic tomorrow when its light out.
MAXXLINK FTW
So, not a fan of the way my truck looked with a black plastic bumper, so with a little work I painted it.
also started in on my doors. started working on the driver door, but didn't take a pic of it. but you get the point
whats this
rocking 6 sets total. doing 4 in the doors, a pair behind me, and another pair in the bed.
whats this
Trending Topics
ok, got more deadening done today. infact got it finished WHOOT...
my lonely 18 box waiting for its moofer... sitting in its groove.. got the box to sit right at the window line.. MIGHT be able to get a hair more... I'm hoping that at shows judges will be strait with it... because at eye lvl its CLOSE...
