Rear Disc Brakes - From a Ram?
Old Oct 8, 2014 | 08:01 AM
northgator8's Avatar
northgator8
Default Rear Disc Brakes - From a Ram?
I have a rear drum issue on my 08, and have been thinking about discs anyhow.
Looking at the parts on a RAM, I'm thinking that a direct swap is possible. Anybody have any thoughts? If I can find a 3rd gen 1500 with rear discs at my U-Pull yard, I might have a go for a few bucks.
Old Oct 8, 2014 | 11:31 AM
I would thinik if it's a 9.25 should be a direct swap.
Old Oct 8, 2014 | 12:19 PM
dakotaff's Avatar
dakotaff
Here's an older thread on rear disc brakes, check it out.
Click Me
Old Oct 9, 2014 | 09:52 AM
northgator8
Thanks, did a search, but three pages in, I hadn't found this.
Old Oct 13, 2014 | 09:16 AM
northgator8
Well, I've found a nice late-model Grand Cherokee with rear discs. Looks like it might just bolt right up. I might grab the parts and see about installing them next spring. My only concern is pulling the rear axles to get the backing plate changed. Likely due for a rear-end fluid change by then anyhow, so it might just happen.
EDIT: Never mind . . . . looks like the backing plates are different because the rear end is a dana rather than the corporate unit.
Old Oct 14, 2014 | 01:48 PM
sparks1032's Avatar
sparks1032
Keep us updated my rear brakes have been a pain as well
Old Oct 15, 2014 | 01:33 PM
rodslinger's Avatar
rodslinger
Default I went through this search too
I came across this and they specifically list a conversion kit for 2005+ Dakota with parking brake. I haven't pulled the trigger yet but am tempted when it comes time for brakes again.
http://www.circletracksupply.com/rea...ge-trucks.html
Old Oct 15, 2014 | 03:58 PM
Dragon05's Avatar
Dragon05
now that looks interesting for $635. Might be my tax money next year.
Old Oct 16, 2014 | 07:33 AM
northgator8
Where's the fun in a bolt-on kit that isn't rusted on to something else to start with . . .
And $635 there makes it totally unaffordable here.
Old Oct 20, 2014 | 11:47 AM
rodslinger's Avatar
rodslinger
You're in Canada. Just open the box and let it set for a few hours. It'll rust....
I was also thinking myself about snagging stuff off a Ram 1500 but not sure what year is the best to use. I was reading that the some 2010 and later Ram's went to an updated differential setup so not sure if that had any impact on the axle housing also. I also can't find confirmation that the axle end bolt patterns are the same between the Ram and Dakota. If I can find a complete rear end with discs for cheap out or a Ram locally it would be worth the test. Am guessing anything from about 2005 to 2009 would be ideal.
