wheel bearing hub 2010 dodge dakota
Old Jun 6, 2015 | 04:37 PM
2010dodgedakotaone's Avatar
2010dodgedakotaone
Default wheel bearing hub 2010 dodge dakota
dose anyone know an easy way to take the hub off a dakota 2010 4wd.i have been hitting old hub to get it off and i get nothing. i took all the screws out that need to be taken out, i need to get it back together before monday.
Old Jun 6, 2015 | 06:14 PM
Check out the third gen dakota section, should be some help in there.
Welcome to DF!
Old Jun 7, 2015 | 11:55 AM
kenttt's Avatar
kenttt
On our '05 I took the yoke off so I could beat the snot out of it on the bench, couldn't get a good enough swing at it whilst it was on the truck.
Old Jun 7, 2015 | 12:06 PM
Deer Hunter's Avatar
Deer Hunter
Hubs rust weld themselves to the knuckle rather quickly, which can make it a real task to remove one while the knuckle is still mounted to the truck. I removed the knuckles and set them up on wood blocks. 4-5 shots with a BFH(big f-ing hammer) and they popped right out. Clean the rust out of hole for easier reinstall and apply anti-seize in case there is a next time. If there is a next time, hopefully there won't be, you should be able to knock them out without removing the knuckle. Good luck
Old Jun 8, 2015 | 08:40 AM
northgator8's Avatar
northgator8
Hope you got this done so you could get to work this morning, but if you can weld, there is a fixture you can make - sort of a T made of angle that bolts on to two of the studs with an arm coming 18" or so out from the face of the hub - you whack that with a BFH and it pops the hub out of the knuckle, likity split!
