Transmission temp light/solonoid pack replacement
Old Jun 22, 2015 | 04:14 PM
Daswatitdo's Avatar
Daswatitdo
Default Transmission temp light/solonoid pack replacement
Hello to all...
I have a 2005 quad cab SLT 4.7
Been dealing with the tranny temp/shifting issue. Shop replaced the solonoid pack, and the the trans temp light still comes on and acts the same before the new pack. Can anyone shed some light here. I've been searching the forum for a while and have found posts here and there...but I'm only on page 51 of 600+ and I'm not sure what I should tackle next... Don't want to keep replacing parts with no positive results. If anyone can offer some advice or know of any links with some sort of remedy it would be greatly appreciated.
Old Jun 25, 2015 | 08:32 PM
stonny9's Avatar
stonny9
Your trans is probably slipping and needs a rebuild or your torque converter isnt locking up.
Old Jun 27, 2015 | 07:32 PM
Daswatitdo's Avatar
Daswatitdo
Thanks for the reply Stonny9... I've been reading up on this for quite some time now.. And I do agree... It could be the torque converter... I do believe the trans itself is fine... But some component of the system is failing...don't think I need a rebuild. Dealership has it now..will find out shortly... Apparently this is a relatively common problem... And has been dealt with by others... And I honestly thought this post would generate lots of useful info... Guess not. However I do appreciate you taking the time to offer a helping hand. One again thank you Stonny9
Old Jun 28, 2015 | 08:11 AM
stonny9's Avatar
stonny9
I would think the dealer would be able to command a torque converter to lock up and look for slippage as it is an electronic transmission
Old Jul 13, 2015 | 06:54 PM
sethgtrx4's Avatar
sethgtrx4
Im in the middle of this same issue. I just replaced the pack and did a complete service. Ive done some research and it might be the PCM. Powertrain control module. Shop is gong to get my truck later this week, Ill keep you guys posted.
Old Aug 2, 2015 | 07:56 PM
Daswatitdo's Avatar
Daswatitdo
It's the pcm.. 200 dollar plug and play part... Don't let the dealer screw you.
Old Aug 6, 2015 | 09:56 AM
sparks1032's Avatar
sparks1032
Ok having a similar issue can someone clarify that this is going to fix the intermittent Trans Temp issue? What were the symptoms prior? If any? Thanks
Old Aug 12, 2015 | 10:17 PM
Daswatitdo's Avatar
Daswatitdo
My symptoms were when the trans temp light came on... The truck would instantly begin shifting irregularly... Which is apparently a design feature to help protect the transmission.
The trans temp light would come on periodically when I bought it with about 50,000miles.. Then it became more of a regular occurrence until about 110,00 when it came on like clock work. I took it in for repair..... The Solenoid pack was replaced..... Didn't help.
Put the old pack back in.... Changed the PCM.....and problem solved.
Trust me... It wasn't as simple as it reads... Dealt with all sorts of needless bull... But if it's the trans temp light.... Odds are this is your fix or one of the most likely causes.
Old Aug 14, 2015 | 01:00 AM
sethgtrx4's Avatar
sethgtrx4
I just installed my refurbished pcm...Auto computer exchange did the refurbish job. but now Im having a no start situation. no errors on the dash either. I have a message out to the business to confirm that maybe I need to disconnect the harness for the RFID (chipped key system?) near the ignition. I did this and still no start. Im hoping that I can still use my computer to drive the truck..any info on this?
Old Aug 14, 2015 | 10:17 PM
Jaded's Avatar
Jaded
Just did a search for this Auto Computer Exchange. I see a lot of complaints of people getting bad units in the reviews.
