2008 radio removal
Old Aug 23, 2017 | 02:55 PM
GameOgre's Avatar
GameOgre
Default 2008 radio removal
So I'm having no luck, can anyone direct me to ANY information on removing the stock radio from a 2008 quad cab Dakota?
I have no idea how to get the panel off.
Old Aug 23, 2017 | 03:47 PM
If its the same as the 05-07, this should help.
https://dodgeforum.com/forum/3rd-gen...-painting.html
If not, the process should be the same. There are screws holding it on the bottom and the rest of it pops out with a little prying.
Old Aug 23, 2017 | 07:22 PM
philipat's Avatar
philipat
The trim is different from the 05-07 trim, but it goes on/off the same way. Like jkeaton said, there are two screws on the bottom of the trim and under the A/C dials. After you've removed those, the rest pops off since it's held in by clips.
Old Aug 24, 2017 | 08:51 AM
GameOgre's Avatar
GameOgre
Thanks!
Crutchfield says I will have to remove the rear support bracket to make my new double din fit.
Suggestions on best way to accomplish this?
Old Aug 24, 2017 | 09:27 AM
LOL..... remove the radio and look at it to see what you will need to do.
Old Aug 24, 2017 | 10:12 AM
dakotaff's Avatar
dakotaff
This thread may help.
Old Aug 24, 2017 | 05:52 PM
philipat's Avatar
philipat
Originally Posted by GameOgre
Thanks!
No idea. I replaced my stock radio with a UConnect. So, it dropped right in with the OEM brackets.
I'm sure it's just some bolts, though.
Old Aug 25, 2017 | 03:17 AM
WhistlerMack's Avatar
WhistlerMack
Thanks!
That link that dakotaff posted has a good write up on the steps needed.
Although, after bending the 2 pieces of steel back I still couldn't fit my double DIN stereo in. I ended up taking a hacksaw and cutting the entire top from the support bracket. Its a pretty solid bracket so its hard to manipulate if you need more room.
Old Aug 29, 2017 | 12:48 PM
GameOgre's Avatar
GameOgre
Yeah, I was worried it was going to require something like this. Guess I could use my cut off wheel in there.
