A/C-heating fan not blowing strong
Old Jan 29, 2018 | 10:35 PM
CPO Hazard's Avatar
CPO Hazard
Default A/C-heating fan not blowing strong
My fan does not blow very hard any longer. It seems to be blocked up. I've cleaned the vents out with a vacuum and a long tube. Sort of like snaking your plumbing. I've been told to change the cabin filter by mechanics. So, as far as I can tell, most vehicles have an internal/cabin A/C filter. The Dakota does not. The Haynes manual does not refer to anything about this issue. Actually, it doesn't cover any troubleshooting of the system at all. Anyone have an idea where I should be looking to clear out any debris that would be blocking air flow?
Thanks.
Old Jan 30, 2018 | 08:00 AM
Please provide your vehicle specifics (year, engine size).
Old Jan 31, 2018 | 12:09 PM
dakotaff's Avatar
dakotaff
There is definitely not a cabin air filter to change in your truck.
Can you hear the fan blow harder when switched all the way up? Or does it stay the same speed as the lower setting?
Old Feb 6, 2018 | 11:23 AM
superdak05's Avatar
superdak05
turn your fan motor to high, start switching the control **** for your circulator door. probably stuck and just needs to find its happy medium.
Old Feb 6, 2018 | 07:31 PM
Jaded's Avatar
Jaded
I changed mine in my car recently, was "blown away" by how much more air the new one pushed compared to the old fan. Guess they slow down over time - wear out.
Old Feb 7, 2018 | 06:43 AM
erau's Avatar
erau
In addition to the blower motor wearing out as noted above, all air coming into the HVAC assembly behind the dash passes through the A/C evaporator coil first (whether or not the A/C is "on")...Without a cabin filter, this evaporator coil may very well have become clogged with dirt/dust/debris/pet hair over the years, and that may be the "blockage" you're looking for. It's not impossible to clean...An option is to pick up a can of foaming evaporator cleaner (can be found on Amazon and probably other retailers), and get access to the evaporator by removing the blower motor on the bottom of the HVAC assembly on the passenger-side (3 screws and a wire harness). The evaporator is just beyond the blower inside the assembly, and there's enough room (once the blower is removed) to reach the can into the assembly and spray it with the little red tube toward the evaporator. You'd want to follow all instructions on the can.
Old Feb 15, 2018 | 12:52 AM
CPO Hazard's Avatar
CPO Hazard
Originally Posted by jkeaton
please provide your vehicle specifics (year, engine size).
2006 slt v8
Old Feb 15, 2018 | 12:55 AM
CPO Hazard's Avatar
CPO Hazard
The fan is working fine. Air is correct temp for setting. There just isn't any force from vents. The mechanical parts of the system are in great condition, and the system was checked by my mechanic recently. They just didn't check the flow of air from vents.
