Leaf spring center pin w/lift blocks
Old Apr 6, 2018 | 08:31 AM
machz830's Avatar
machz830
Default Leaf spring center pin w/lift blocks
I plan on installing 2" lifting blocks for my rear suspension of my 06 r/t. My concern is that the leaf spring center pin/bolt does not come out and after installing 2 inch blocks, it will obviously not stick all the way through the leaf springs. What is the correct way on installing lift blocks with a stationary/non-removable center bolt? Thank you for any advice-love the site s far!
Old Apr 6, 2018 | 12:16 PM
This looks strangely familiar........
Thought you already drilled out the blocks?
Old Apr 6, 2018 | 12:46 PM
machz830's Avatar
machz830
I did but then I asked if I was just supposed to leave the bolt/pin 2 inches short to where it would not come out the top of the leaf springs or another option?? I had no response and would like to get this installed but on the same note, I don't want to install the blocks knowing the centering pin will not be through all of the leaf springs if I don't know that it will be safe.
Old Apr 6, 2018 | 12:53 PM
I still go back to did you buy the correct blocks? Did they come with any instructions or anything? I installed a 2" add a leaf on mine. So I didn't have to deal with a block of metal, but I agree, wouldn't be too safe with the leafs being able to slide back a forth. I don't know what to tell you at this point. Hopefully, someone on here has installed blocks that can chime in.
Old Apr 6, 2018 | 12:59 PM
If you search "rear lift blocks" in this section, there are several old threads about the issue you are encountering. Maybe that will help you out.
Old Apr 6, 2018 | 01:02 PM
machz830's Avatar
machz830
Thank you!
Old Apr 9, 2018 | 12:18 PM
rookie's Avatar
rookie
Dont mess around. I have alloy blocks with a tab on the bottom and a slot on the top. I think the leaf pin fit into the slot on top of the block and the tab on the bottom of the block went into the slot on the spring mount. I tell you this for two reasons: 1 the importance of the pin, and 2: dont use the alloy blocks. I wheel kinda hard sometimes, and the alloy blocks deformed and the tab sheared off. My axle slid back on the leaf spring one day offroad, as a result of not having an effective locator pin system.
Old Apr 9, 2018 | 02:34 PM
machz830's Avatar
machz830
Thank you for the info Rookie!! I appreciate it.
