Engine Light Flashing and Driving Rough
Old Dec 28, 2018 | 02:37 PM
Trout027's Avatar
Trout027
Default Engine Light Flashing and Driving Rough
I have an 06 Dakota with 174,000 miles on it. It has been a great vehicle. Now after the truck is warm, shut off, and then start up to drive shortly there after I have had the engine light flashing and the truck running real rough.
The codes pulled were Engine Misfire and also Closed Loop fueling not achieved.
Any experience with this or help would be greatly appreciated before I just start replacing parts in hopes of fixing?
Old Dec 28, 2018 | 03:42 PM
What are the specific codes? That should narrow down what cylinders are causing the issue. Continuing to drive can result in damage also.
Old Dec 28, 2018 | 03:51 PM
Trout027's Avatar
Trout027
When I took it to O'Reilys that was the specific codes they said it pulled. Maybe their system is not as high tech as needed to be.
Old Dec 28, 2018 | 04:20 PM
You need to have the exact code to identify which cylinder is misfiring.
Old Dec 28, 2018 | 08:00 PM
Gary's Pistol Grip's Avatar
Gary's Pistol Grip
Default DTC's
Diagnostic Trouble Codes (DTC's) consist of a letter followed by at least 4 digits. Then the tools like O'Reilly's just looks up the English description. So they only told you the general description but we need to know the exact code to give you a helpful answer. Seems they just told you "Misfire" but the code that goes with that can get more specific. i.e. P0300 = General misfire, but P0304 = Misfire cylinder #4.
Old Dec 28, 2018 | 08:27 PM
Al Glover's Avatar
Al Glover
Default Rocker arms
Am tedoing a head gasket on my 4.7 i lost two rocker arms on my cylinders 4&6 on the exhuast side passenger side head too. It sounds like what i went thru... overheating no reason no leaks and sounds like it is flooding but pops to get back to normal. Check the heads!
Old Dec 31, 2018 | 08:23 AM
dakotaff's Avatar
dakotaff
Get yourself an
<b>OBDII code</b> OBDII code
reader, everyone on these forums should have one, they are as cheap as
<b>$11</b> $11
nowadays.
Old Dec 31, 2018 | 12:01 PM
FaceDeAce's Avatar
FaceDeAce
Step 1 - replace the spark plugs. NGK V-Power, copper. DO NOT use platinum or iridium plugs.
Which engine is in your truck?
Old Dec 31, 2018 | 09:31 PM
rodslinger's Avatar
rodslinger
Yes. This.
Get back to basics and make sure regular maintenance items are in good shape. New spark plugs, clean air filter, etc. Visible inspection to make sure there are no loose or damaged vacuum or emission hoses.
