Help a.girl out. Transmission problems
Old Mar 11, 2021 | 12:28 PM
dopree martinez's Avatar
dopree martinez
Default Help a.girl out. Transmission problems
Hi, I have a 3rd generation Dodge Dakota. It's a 4 by 4, 8 cylinder automatic . It shifts fine from 1 to second but slips right out of 3rd. The code " improper gear ratio." What the heck does that mean. And what should I try Before I take it to the tranny Shop . I do most my repairs myself or at least try toBut I'm afraid transmissions might be out of my league I won't know until I try
Old Mar 11, 2021 | 01:44 PM
What is the actual code? I assume you have checked the fluid level and condition?
Old Mar 11, 2021 | 01:48 PM
pilotsmack's Avatar
pilotsmack
Start with the fluid level, and it does change from cold to hot. You need a level surface, and to check the level in neutral with the engine running (and the parking brake on, obviously).
Old Mar 12, 2021 | 11:04 AM
dakotaff's Avatar
dakotaff
Errors like these are usually a serious problem, could be an accumulator or cluch issue, but most likely you'll need a transmission shop on this one.
It may require a rebuild kit.
Old Mar 12, 2021 | 02:03 PM
superdak05's Avatar
superdak05
2 things, you have a bad shift solenoid, or your fluid and filters need to be changed along with a complete flush. I would start with a complete flush and new filters and fluid. and welcome
Old Mar 12, 2021 | 05:18 PM
dopree martinez
Default Update
I did the filter and fluid change, twice. No metal shavings in the fluid. I.domt have the actual code . right now., loaned out my meter. Fluid levels are good
Old Mar 12, 2021 | 05:28 PM
dopree martinez
Default Hi,
U have given be good advice in the past, do you think it would be a waste of time and money to do the solenoids because that's what I was going to try next
Old Mar 12, 2021 | 06:52 PM
dakotaff's Avatar
dakotaff
I guess it can't hurt to try, you might get lucky and get that Dakota rolling again. I know unless you have a trusted mechanic to bring it to, that should be a last resort. Transmission issues are definitely one of the worst things you'll have to deal with with any vehicle.
Old Mar 12, 2021 | 11:49 PM
pilotsmack's Avatar
pilotsmack
Does your scan tool do live data? I'd be curious what the line pressure is doing when it slips.
Also, the trans that came with the V8 has 2 filters... the main pan filter (big flat one), and a spin-on that filters the oil cooler loop. Did you replace both when you did your trans fluid? Or just the one?
