exhaust manifolds
Old Jul 15, 2021 | 04:38 PM
GalvaThunder's Avatar
GalvaThunder
Default exhaust manifolds
Anybody know of some headers that will fit the 08 and newer dakota with the 4.7? I've got manifold leaks, looks to be just the gaskets at the moment, don't think the manifolds are bad but they have to come off to put new gaskets on and I was thinking it would be the perfect time to put on some aftermarket headers but I'm having trouble finding anything; everything seems to be for the previous model trucks (07 and older), Anybody got some links or info?
Old Jul 15, 2021 | 08:34 PM
philipat's Avatar
philipat
I would broaden your search to include Ram 1500s. They used the same engine.
Old Jul 15, 2021 | 11:05 PM
GalvaThunder
A lot of those come up but do they fit in the dakota's engine bay, the truck is smaller than a ram.
Old Jul 15, 2021 | 11:35 PM
dakotaff's Avatar
dakotaff
I'd ditch the headers idea and just repair what you need with your exhaust manifold. Make sure there are no cracks in the manifolds, and have a new set of bolts on hand with the new gaskets. The leak is usually caused by broken exhaust manifold bolts, so be prepared before you begin.
And yeah, there isn't enough room to fit the headers that are made for our Dakotas, so definitely a no-go on any listed for a Ram 1500.
Old Jul 15, 2021 | 11:41 PM
GalvaThunder
Think any made for the 05-07 dakotas would fit my 08 or is there too much difference in room and the updated engine?
Old Jul 16, 2021 | 12:27 AM
pilotsmack's Avatar
pilotsmack
Im also tending to think broken manifold bolts. Way more common than most folks realize. Usually a fairly cheap fix, depending on the break.
Not sure about fitment of other manifolds.
Old Jul 16, 2021 | 06:45 PM
dakotaff's Avatar
dakotaff
I recall the 05-07 headers wouldn't simply fit in those years, there was usually some space issues. I'd say almost 100%, they won't work in your truck.
Old Jul 26, 2021 | 11:22 AM
superdak05's Avatar
superdak05
forget headers waste of money, the factory logs flow just as good, the restriction is the y pipe collector, spend the $ 75 and get a larger one or have a custom shop fab you up one, I did and went with a 3 inch single catback system from magnaflow,
Old Jul 26, 2021 | 07:55 PM
philipat's Avatar
philipat
Where did you get the larger y-pipe collector? Was it custom-made or pre-fabbed?
