2005 Dakota P0172
Old Jun 26, 2025 | 04:39 PM
jmc0281x's Avatar
jmc0281x
Default 2005 Dakota P0172
May 05 Dakota 4.7 is giving a P0172 code. I’ve replaced the PCV Valve, all 8 injectors and Plugs. It still falls flat on its face when under acceleration. I’m at a loss of what to check next. Any suggestions would be greatly appreciated.
Old Jun 26, 2025 | 04:44 PM
How old are the O2 sensors? What did the plugs look like? Especially those on the effected side.
Old Jun 26, 2025 | 04:48 PM
jmc0281x's Avatar
jmc0281x
They were in bad shape. I believe they are the factory O2 Sensors
Old Jun 26, 2025 | 06:00 PM
Jaded's Avatar
Jaded
I'd start by looking at the vacuum lines. Smoke test the intake. If that passes, I'd move on to compression test.
Old Jun 27, 2025 | 07:51 AM
Replace the front O2 sensor. Denso, or NTK sensors ONLY please. Skip Bosch. These trucks don't like 'em.
Old Jul 5, 2025 | 11:27 PM
jmc0281x's Avatar
jmc0281x
Is this a good O2 Sensor read
ing
Old Jul 6, 2025 | 09:34 AM
Rear sensors are not reading even close to the same there..... Does yours have dual cats??
Old Jul 6, 2025 | 11:17 AM
jmc0281x's Avatar
jmc0281x
It has dual cats.
Old Jul 6, 2025 | 12:17 PM
Hhhmmm.... So, possibly a bad sensor, or maybe an inefficient cat..... The front sensors appear to be reading just fine though...... Could try replacing the rear O2 sensor on bank 1..... Don't know if that will fix it though. Will your scanner show what it thinks the mixture ratio is??
Old Jul 6, 2025 | 01:14 PM
jmc0281x's Avatar
jmc0281x
I think it will, I will have to check
