2006 Dakota SLT loss of power
Old Oct 12, 2025 | 03:54 PM
Teo132's Avatar
Teo132
Default 2006 Dakota SLT loss of power
I have a 2006 Dakota SLT, it has been experiencing random power loss after start up. No codes, no CEL. Mash the accelerator and after about 3-4 seconds it clears up and takes off. Most often there will be no other instances. Until the next times we turn it off and back on. Does not happen with every start up. Of course it did not happen at any of the 3 different mechanics that have worked on it this year.
Has brand new motor (separate issue water pump went out and the engine locked up). Brand new transmission. Also brand new computer. Problem existed before all these items were replaced.
Any ideas?
Old Oct 12, 2025 | 04:04 PM
So what's still on there that's involved with running the engine, that DIDN'T get changed? TPS? If it's an electronic throttle body, Pedal Position Sensor?
Old Oct 12, 2025 | 04:09 PM
Teo132's Avatar
Teo132
I would say yes to all three of those. Of course we can toss all three on there and see which one fixes it. I'm surprised by the lack of CEL. When my 2004 Acura had the TPS and throttle body go bad, each threw a code and forced limp mode and required a restart. This just clears itself and takes off.
Old Oct 12, 2025 | 04:10 PM
Teo132's Avatar
Teo132
btw, I'm new to the forum and have no idea where that user name came from. Is it possible to change it? I looked thru all the user options and control panel menus, but didn't see it.
Old Oct 12, 2025 | 05:05 PM
I suspect I have the ability to change it.
I would be tempted to acquire a scanner, and see if you can catch what it going on. Log TPS and APPS while driving, when it screws up, check the logs, see if either of them is doing anything strange.
What would you like your username changed to?
Old Oct 12, 2025 | 05:53 PM
Teo132's Avatar
Teo132
Teo132
Old Oct 12, 2025 | 06:00 PM
Originally Posted by Teo132
Teo132
There ya go.
Old Oct 12, 2025 | 08:05 PM
Teo132's Avatar
Teo132
Thank you very much. Now I guess I get to buy a better code scanner. I have a basic one but no logging features. Just reads CEL codes.
Old Oct 17, 2025 | 02:51 PM
Hesselhoff's Avatar
Hesselhoff
The 2006 has a cable driven throttle body, it wasn't until 2008 that they moved over to electronic throttle control. Most code readers can only read powertrain "P" codes as those are what typically trigger the engine light (MIL). A higher end scanner or computer software with a usb-obd cable can get more codes from different modules (B, C, P, T & U). The free factory service manual at the top of the forum has a list of codes and diagnostic checks to figure out exactly what needs to be fixed. If you are good with computers, I would recommend the software approach, otherwise the dedicated scanner is the simple option.
