Wont turn over
Old Dec 16, 2025 | 07:45 PM
Aldencrain's Avatar
Aldencrain
Default Wont turn over
Seems always to start when cold, but intermittently when I turn the key I get absolutely nothing. Battery is new.
Old Dec 16, 2025 | 09:09 PM
Battery cables, connections. Grounds. Check them.
Also, please add your vehicle specifics.
Old Dec 16, 2025 | 09:29 PM
Aldencrain's Avatar
Aldencrain
Default 4.7L flex fuel
Battery connections all clean. I’m thinking positive starter cable.
Old Dec 16, 2025 | 11:25 PM
Dodgevity's Avatar
Dodgevity
Do you get a single click?
Old Dec 17, 2025 | 04:51 AM
Aldencrain's Avatar
Aldencrain
No, nothing.
Old Dec 17, 2025 | 07:20 AM
What vehicle? What year? What engine? How many miles? We don't even know what you are working on.
Old Dec 19, 2025 | 11:25 AM
Dodgevity's Avatar
Dodgevity
Swap starter relay with identical relay, such as AC compressor relay. If working consistently, replace relay.
Old Dec 19, 2025 | 04:35 PM
Aldencrain's Avatar
Aldencrain
Default ‘07 Dakota, 4.7
Swapped relay, got nothing. Ran cable directly from battery to starter, nothing. Stuck a screwdriver across posts on starter and got lots of spark. I believe that means bad starter?
Old Dec 19, 2025 | 07:49 PM
If the starter didn't turn when you did that, yeah, probably bad starter.
Old Dec 19, 2025 | 07:59 PM
Moparite's Avatar
Moparite
Does the relay "click" when you turn the key? You may need another person to listen as it can be hard to hear from the drivers seat. Try powering the small terminal on the solenoid and see if that works.
