New plug time....
Old Sep 18, 2006 | 04:07 PM
JaredGMS's Avatar
JaredGMS
Default New plug time....
So I need to replace the plugs on my 05 V6.....any ideas on a good plug to use? I'm running the K&N 66 series, so I need a little colder plug than stock....
thanks in advance
Old Sep 18, 2006 | 04:51 PM
Flyhalf's Avatar
Flyhalf
Default RE: New plug time....
New plugs already for an 05? How many miles do you have on it?
Old Sep 18, 2006 | 07:01 PM
JaredGMS's Avatar
JaredGMS
23K miles, and I think the plugs are a little "fouly"......i drive the **** out of it, and like to keep it as efficient as possible
so, any ideas?
Old Sep 18, 2006 | 08:21 PM
Frenchy's Avatar
Frenchy
https://dodgeforum.com/m_563095/tm.htm
Old Sep 18, 2006 | 09:34 PM
Blu_Dak's Avatar
Blu_Dak
The 4.7 plugs are suggested for change @ 30K,I lust hit 22K this weekend and getting to that point soon.
Blu_
Old Sep 18, 2006 | 10:47 PM
luvmydak's Avatar
luvmydak
Go with Autolite standard 3923. Colder than stock. Be sure you know what your'e doing, as each plug is capped with it's own dedicated ignition coil.
Old Sep 18, 2006 | 10:54 PM
superdak05's Avatar
superdak05
i just replaced my plugs on my 05 4.7 sunday. 25000 and the electrodes were almost gone. went with the autolitre ap5224 platinum.
seems to run smoother at idle. cant say i have a improvement in mileage yet. but the performance is still the same as was with the factory champions
Old Sep 18, 2006 | 11:05 PM
maxmax's Avatar
maxmax
Changed mine out at 19K. I used the Champion Truck plug 4071. It is just a little better than OEM and has a larger copper core. I have almost 1K on the new plugs. I think the engine runs smoother, just my opinion. Use some air to blow out dirt around the plugs before removal and change the plugs out on a cold engine, also make sure to put alittle anti-seize compound on the plug threads would be my best recommendation.
Old Sep 20, 2006 | 02:36 AM
f0x672's Avatar
f0x672
im runnin ngk dude... purrs like a kitten
Old Sep 20, 2006 | 07:30 AM
lil's Avatar
lil
wow i didn't know the plugs needed changed so soon i have 24k on my 4.7L, is this pretty easy to do yourself ?
