Cold Air Intake
Old Sep 21, 2006 | 10:17 PM
DakotaLee's Avatar
DakotaLee
Default Cold Air Intake
Hey anybody install a cold air intake just wondering of theres any sensors from after the throttle body to the air filter, ya know all that **** that disappears after you put on a cold air kit. I'm thinking of building my own, (low budget kid saving for school) should be pretty simple if there ain't any sensors.
Old Sep 21, 2006 | 10:34 PM
ETXDak's Avatar
ETXDak
Default RE: Cold Air Intake
Just an air temp sensor near the throttle body.held in with a rubber grommet and crank case vent tube plugged in near the filter. pretty simple.You can go to the K&N website and look at the install instructions,plus search this and other forums, alot of people making their own out of pvc pipe.
Old Sep 21, 2006 | 11:09 PM
superdak05's Avatar
superdak05
i bought my k/n fipk off of ebay was only 212.00. was a great investment. if you are going to build your own it will function properly but you wont have the heat shield. this is an important part of the cold air system. as afr as the holes you will need to drill for the iat sensor and the inlet tube for the breather element it should be an easy install
Old Sep 22, 2006 | 02:17 AM
DakotaLee's Avatar
DakotaLee
For sure on the heat should I better take a look at some of the intakes out there but just one sensor with grommet and a tube should be pretty basic.
Old Sep 22, 2006 | 12:39 PM
06dak's Avatar
06dak
When you get it done post pics! I am considering doing the same thing, but don't want to make it too "junkyard wars" under the hood...
I don't have the excuse of being in school, I'm just cheap
Old Sep 22, 2006 | 12:47 PM
turbot_bird's Avatar
turbot_bird
ORIGINAL: 06dak
+1 just I do have to worry about collage lol
Old Sep 23, 2006 | 12:14 AM
DakotaLee's Avatar
DakotaLee
Took It All Off Its Simple Till The Fact That The Sensors Some Goofy Twist in no thread but it still has a grommet on it to I could get it to seal but to really hold it it I dunno can't **** it up
Old Sep 24, 2006 | 10:11 PM
Disgorilla's Avatar
Disgorilla
Here's my K&N CAI...Shel
[IMG]local://upfiles/22121/23DF1843A5F0405F8B8F90C4B437E088.jpg[/IMG]
Old Oct 1, 2006 | 03:17 AM
studlyblueiz's Avatar
studlyblueiz
I have the high output V8 and was considering a cold air intake too; but mine looks like it filters through the fenderwell down underneath the bumper...do the regular 4.7's do that too? or should i just leave this setup?
Old Oct 1, 2006 | 08:25 AM
Frenchy's Avatar
Frenchy
it doesn't filter down there, the filter is still in the huge box, that thing that goes into the fenderwall is just what draws the air into the stock airbox.
