How Many PPL get bad wheel hop when turning and accelerating
Old Sep 29, 2006 | 01:46 PM
DakotaLee's Avatar
DakotaLee
Default How Many PPL get bad wheel hop when turning and accelerating
I get it bad, took the truck in some sand in 2wd and it was horrible, I hope it ain't like this in 4wd because I don't want to be feathering the throttle when I'm getting suck or something.
Old Sep 29, 2006 | 01:57 PM
superdak05's Avatar
superdak05
Default RE: How Many PPL get bad wheel hop when turning and accelerating
i only get a little wheel hoop coming off the line. i have the corporate rear with the 3.55. and if i make a tight u turn you can fell the back end skip a little
Old Oct 3, 2006 | 10:20 AM
sdsdsd's Avatar
sdsdsd
I get it too, especially when it's wet out. I figure it's due to the posi rear. I was thinking about taking it to the dealer, I believe there is an differential oil additive to stop that.
Old Oct 3, 2006 | 10:52 AM
bkjtimp's Avatar
bkjtimp
Yep...Mostly when acc. from a stop and turning. Must be when only one wheel is starting to break loose and the LSD is trying to lock or whatever. I can deal with it, knowing when I need to throttle back. Doubt it's fixable.
Old Oct 4, 2006 | 12:46 AM
06dak's Avatar
06dak
It's the nature of limited slip... when one wheel starts to slide, the torque (power) gets transferred to the other wheel. If you're going around a corner, that will cause hop because the wheels are trying to go the same speed due to power but can't because the outer wheel travels farther than the inside wheel. No fluid will fix this, it only may soften the transition from one slipping to the other engaged. You'll still get the hop, especially under power or with high torque (I can't floor it on dry pavement around a corner with the V8) When you're stuck, though, it shouldn't crop up too much - as long as you're going straight! Both tires should rotate like no ones buisness. To get out, though, you really need to slowly power out. 4WD should be no problem - the front tires will pull you out.
Old Oct 4, 2006 | 05:43 AM
trucky's Avatar
trucky
lolololol that is the funniest topic ive ever seen...when ur going around a corner in a TRUCK and accelerating your GONNA hop the wheel there low weight in the back and thats rear wheel drive. dee dee deeeee
hey....i get bad wheel spin when im mudding...is that normal? muahahaha sorry just had to poke fun
Old Oct 4, 2006 | 09:49 AM
sdsdsd's Avatar
sdsdsd
Trucky, for your information I have owned other trucks that don't wheel hop when accelerating while turning Dee Dee Deeee!
Old Oct 4, 2006 | 09:51 AM
sdsdsd's Avatar
sdsdsd
There is a fluid additive to lessen this problem referred to as chatter.
Old Oct 6, 2006 | 06:50 PM
skinsfan's Avatar
skinsfan
I have same thing on wet roads starting from a stop and some turns. (I also have the corporate rear with the 3.55) Nothing major, but I think it is just the nature of a truck. With the V8 Magnum if you don't feather the throttle you can spin them for quite a ways....[:-]
Old Oct 6, 2006 | 07:15 PM
trucky's Avatar
trucky
thank you for the logical back up, im always right
