My o5 Dakota in the shop
Old Feb 11, 2007 | 06:45 AM
DynoDan's Avatar
DynoDan
Default My o5 Dakota in the shop
Hi I am new and I have had my o5 Dakota in the shop 4 days in 2 weeks. It was the check eng. light. First they changes the Ox sensers and when that did not work thay are saying its the Cat converter. Any one out there experance this if so please respond Thnks DYNO
Old Feb 11, 2007 | 07:54 AM
snobrdrdan's Avatar
snobrdrdan
Default RE: My o5 Dakota in the shop
Well how many miles are on your truck???
Usually takes some good corrosion or a lot of miles for a cat. to go bad
But if it's under warranty and being taken care of.......why care??
The problem starts when they can't fix it, if you ask me
Old Feb 11, 2007 | 01:59 PM
superdak05's Avatar
superdak05
no, but if it is coming up evap code your gas cap might be at fault.
Old Feb 11, 2007 | 02:37 PM
Dusty's Avatar
Dusty
If its your cat that should still be under warranty. GM warranties their cats for 88,000 miles. If they don't warranty it, get the catless Y-Pipe from the earlier HO motor and get some downstream O2 sims. MUCH cheaper and you'll have more power to boot.
Old Feb 11, 2007 | 02:45 PM
DynoDan's Avatar
DynoDan
Thnks for the info guys i am intrested in the downstream O2 and the catless Y pip any websites.
Old Feb 11, 2007 | 02:49 PM
Dusty's Avatar
Dusty
I was told (but I never verified) that the Catless Y-pipe is available at the dealer for less than $60. For the 02 sims I haven't really looked around yet. Basically any 02 sim would work, just need the right plugs on the ends.
Old Feb 12, 2007 | 01:54 AM
butchowens's Avatar
butchowens
My truck did just this. Buy a new fuel tank cap and try it. The locking one is less than $40.00. The shop had trouble finding why my ck eng light came on as well.
Old Feb 12, 2007 | 05:02 PM
MoparMafia's Avatar
MoparMafia
you guys should do what i do when these lights come on. put a businesscard over it on the dash. problem solved. i've never had a car/truck quit running or breakdown because of the check engine light. i think it's a gimmick for the stealership to get you in. if it covered under warranty they get paid. if it's not under warranty, they still get paid. 1 big damn conspiracy
Old Feb 12, 2007 | 05:10 PM
Chris's Avatar
Chris
ORIGINAL: MoparMafia
Um, well... A CEL can be a window to a serious problem. A lot of times they are codes that can be irritating, however, if your motor is shuddering and you can't find the solution, that CEL will allow you to see what your computer has to say about it. Covering up a CEL and not just fixing the problem is the fastest way to guarantee that you will have serious engine troubles down the road. Your Ineffecient Cat Converter code, which you could care less about, could be covering your Crank Position Sensor code, that if goes unchecked, could ruin your motor.
Just my $.02
Old Feb 12, 2007 | 09:22 PM
DakotaMan06's Avatar
DakotaMan06
I let my light go on my last truck cuz I was sick of sinking money into it. One day the timing chain breaks and the motor is scrap metal.
Yeah... so I have a 06 Dakota now and life is good!
