Valve Cover Breathers
Old Feb 14, 2007 | 09:50 PM
DakotaStone's Avatar
DakotaStone
Default Valve Cover Breathers
I was looking at the valve cover breathers and what the benefits of having one installed. Does it help keep the core a little bit cooler and help with the effeciency of the engine, therefore...[:@] Does it make it perform better?
Old Feb 14, 2007 | 11:36 PM
superdak05's Avatar
superdak05
Default RE: Valve Cover Breathers
basically it is a pressure releiver
Old Feb 15, 2007 | 03:26 AM
DakotaStone
Thanks for checking Eric.
Old Feb 15, 2007 | 03:42 AM
turbot_bird's Avatar
turbot_bird
I used them on my 350sbc and my tc and they both saw street use, dont know if it helped much though.
Old Feb 15, 2007 | 03:58 AM
dodgerules86's Avatar
dodgerules86
Stupid question: How are the valve cover breathers you speak of any better/differant than the one(s) already installed for the PCV system?
Old Feb 15, 2007 | 05:52 AM
DakotaStone
If you're talking to me, I'm not sure where the pcv is on our engines. I haven't come acrossed it yet, not to say that it isn't there, I just haven't seen it yet. Also, it's bigger than the ones we would have that's stock. Better breathing.
Old Feb 15, 2007 | 11:52 AM
dpk241's Avatar
dpk241
A valve cover breather and the PCV (positive crankcase ventilation) serve the same purpose. They are there to relieve the pressure that builds up in the block due to the air heating up, oil evaporating, condesation evaporating and blow-by exhaust. The only difference is that the breather vents these gasses directly to the atmosphere and the PCV system draws these gasses into the air intake and burns them, thus reducing emissions. You will not notice any power difference buy adding/switching to a crankcase breather, they are mostly for older engines and race engines.
Old Feb 15, 2007 | 12:05 PM
DakotaStone
Thanks for your answer. It looks like they're good for show too, at least the one's I've seen.
Old Feb 15, 2007 | 12:07 PM
bkjtimp's Avatar
bkjtimp
So, for times NOT doing your emmisions inspection, we could put one of those cool looking filters on and be okay, huh? I wonder if where the PVC hose goes onto the valve cover is threaded that would match the threads on the air filters.
