window cracked from cold?
Old Mar 2, 2007 | 01:41 AM
strikeu's Avatar
strikeu
Default window cracked from cold?
I went out to start the 3500 CTD Dually that I have had 4 Months, opened the door, sat in , put the key in the ignition, (it's cold, about 25 and snow), hadn't even started the motor yet, closed the door normally and the Driver Window CRACKED! wtf? all the way across the bottom. I didn't slam it, nothing hit it, no heat, I just pulled the door closed normally and CRACK!
anyone ever hear of this?
thanks
Old Mar 2, 2007 | 01:56 AM
strikeu's Avatar
strikeu
Default RE: window cracked from cold?
yeah, I was thinking defect, I wonder if this is a warranty item.
Old Mar 2, 2007 | 02:30 AM
superdak05's Avatar
superdak05
yep, you are not the only one. wwwdodgetruckworld.com has several of there members with the same problem. might want to look into this somemore
Old Mar 2, 2007 | 04:25 AM
jimboscomp's Avatar
jimboscomp
O_o weird...I had a friend who went outside, found ice on her windshield, and being from california, and an exaggerater comes in freaking out like the world has tilted off its axis, goes back outside with hot water and cracked the windshield...and it was about 25, but not doing anything shouldn't do that. Is the dually brand new or was it bought used?
Old Mar 2, 2007 | 07:06 AM
Gerrard155's Avatar
Gerrard155
I live in Alaska and have seen temps of as low as -65. Neither I, nor anyone I know, have ever had this problem. This is definitely not a temp issue and I would go to your dealership if your truck is still under warranty and have the windshield replaced.
Old Mar 2, 2007 | 08:54 AM
motopimp's Avatar
motopimp
ORIGINAL: ericemery
sounds to me like a defect...
Gotta love outsourcing, in the end it's our name, reputation and customer satisfaction ratings that take the hit!!!!!!!!!!
BTW:I'm not saying it isn't possible and never happened with in house stuff.
Old Mar 2, 2007 | 12:46 PM
strikeu's Avatar
strikeu
Bought it new in Nov 07, I havent even gone over 4k miles yet.
Old Mar 2, 2007 | 01:53 PM
mb18's Avatar
mb18
it is a side window. there was another story a few posts up about a girl who dumped hot water on her windshield and cracked it, but the guy with the original problem (and what is probably a sweet dually) had his problem with the driver's window.
