3rd Gen Durango 2011+ models
IPod and Mediacenter 430?
Old Jun 27, 2011 | 01:10 PM
  #21
cbrrider012's Avatar
cbrrider012
Is this going to be an update that we are able to do ourselves? By cd or usb with an iso file? If so whenever it comes out would you be able to send us the download link to do this?
Old Jun 27, 2011 | 03:11 PM
  #22
xsdbs's Avatar
xsdbs
This will be an update that will be given to the service dept by Chrysler, it will be on their dealer connect system which is their technical website. The file will have to be downloaded to a USB flash drive and then be installed using the USB connector that is used for iPod / USB audio connections. If I were to post the SW update and Chrysler found out I could get into trouble. So legally it will have to be done at the dealer level.
Old Jun 28, 2011 | 10:37 AM
  #23
cbrrider012
That sucks... guessing there is no way to get to the technical website ourselves either?
Old Jun 28, 2011 | 11:48 AM
  #24
xsdbs's Avatar
xsdbs
which "Technical Website" are you referring to?
  #25
xsdbs's Avatar
xsdbs
Just to let anyone with an HTC phone (EVO & Shift, There may be a few others but these are the 2 that I am aware of right now) HTC has a SW update for the issues that they are having with the BT dropped connections and the Streaming audio. This update ant the update that Chrysler will be releasing will get your phones working with out dropping the connection. They have done some work on how the Phone book is sent to the Uconnect as well as work on their streaming audio signal. This is the same SW that I tested for them last month and it works on the BT connection, when I originally did the testing, the streaming audio was better but not perfect. HTC did more work on it since then. I know that with the version that I tested along with the Chrysler update that the streaming audio worked well.
Old Jun 28, 2011 | 03:01 PM
  #26
cbrrider012
You said "it will be on their dealer connect system which is their technical website."
That technical website...
Old Jun 28, 2011 | 04:10 PM
  #27
xsdbs's Avatar
xsdbs
Oh, I see where the confusion is. The Dealer Connect site is where the Technicians log into for TSB's, schematics, diagnostic procedures etc. This is not a site open to the public. I can't even access it. You have to be a Chrysler Service Technician in order to get log on information.
Old Jul 13, 2011 | 11:54 AM
  #28
Leman's Avatar
Leman
You are not going to be able to update it yourself?
Actually it is fairly easy. Found this whilst looking to hard reset the unit...
Load the file on a USB stick,
hold the VC and phone button on the unit down
at prompt, plugin USB mass storage, and apparently it does its thing. (Have not tried this part as have no update file....)
Old Jul 13, 2011 | 12:22 PM
  #29
xsdbs's Avatar
xsdbs
well yes the process is easy. The update has been available now since 6-29-2011 and the TSB is 08-036-11. The problem that is now going on is finding a dealer that has a person that can actually read and understand instructions. There have been several people in different states that have tried to get the update done, they are either told that the update does not exist or if they are lucky enough to get someone who says "yeah, here it is" that they actually get it done. If you do get it done and want to make sure that it is done correctly ( some have driven off with their iPhone /iPod working thinking this is great finally!!!! only to be disappointed the next time they get in their vehicle that it doesn't work again and start cursing the update). Turn you streaming audio on, it plays fine, right ( with Apple products) now press the wake button so that the display back lighting is on so you can see the "now playing display". Is the audio still fine (if so then you got lucky) if it is choppy then it wasn't done correctly.
For those with none Apple products, is the streaming audio choppy or fast, then it wasn't done correctly either.
This is not a difficult thing to perform, I went to a local dealer with a rented Durango to get the update performed. I spoke to the service mgr about watching the tech perform the update so I could find out if there was a problem with the update or if it was a technician issue. It is definitely a technician issue.
Old Jul 15, 2011 | 07:23 PM
  #30
xsdbs's Avatar
xsdbs
please see this link for more information
http://www.challengertalk.com/forums...ote=1&p=861317
